View Full Version : '71 500: Will a Flex fan cause me cooling problems?
FlipperFish
01-17-05, 08:48 PM
Thinking of installing a flex fan, same size fan as stock, on my '71 500. Will it provide enough cooling or should I still with the stock setup?
davesdeville
01-18-05, 12:18 AM
If it ain't broke...
Spyder
01-18-05, 01:21 AM
It shouldn't cause any problems, but then again, it shouldn't give you all that much of a gain, either.
Sasquatch
01-18-05, 10:24 AM
If you have a fan clutch on your current set up that will also have to be removed and a spacer installed. A flex fan will not cause enough drag to engage the fan clutch. I would stick with the stock setup. In my 69 Caddy hearse (472) when I bought it there was a flex fan setup. I found the original seven bladed fixed steel fan in a junk yard in town and installed it with a new fan clutch. I figured if it was engineered that way by Caddy it was good enough for me.
