View Full Version : Bad Trans Mount? Pics
jeremy107
05-21-13, 11:23 AM
Was asked to post pics on my trans mount to get some opinions if it was bad and I needed to replace with Revshift support mount. I crawled under the car and snapped a few pics, if need more let me know. Trying to solve this rough shifting problem and nearly impossible to reverse.
darkman
05-21-13, 11:44 AM
It looks totally collapsed to me.
jeremy107
05-21-13, 11:47 AM
Thanks for the reply Dark, maybe the Revshift support block will solve my shifting and reverse issue.. At least I hope so. Anyone else think its toast?
HAMSTAR
05-21-13, 11:48 AM
Is this a monty python sketch? Your mount is dead, kaput, gone, deceased, no more...
jeremy107
05-21-13, 11:50 AM
Lol thanks! Starting to feel the love around here haha Thanks guys Im gonna go ahead and put that Revshift mount on order
JFensty
05-21-13, 06:10 PM
It may just be me, but I would replace the mount too while you are at it. It looks horrible.
jeremy107
05-21-13, 06:51 PM
So the Revshift support block wouldnt fix it? Or do I need mount and support block? The suuport block is pressed into the mount so I would think that would work. At least my guess? Anyone else?
darkman
05-21-13, 07:30 PM
Agree - new mount with Revshift insert for longevity. It would be easier if the OEM mount weren't so pricey.
SevillianSTS
05-21-13, 08:21 PM
I suppose you could try the Revshift block first, cause then if it doesn't look right you still gotta get that one out of there, in which removing the insert would be easy when the mount is off the car.
Your mount is pretty bad, but for cost reasons no reason not to try the Revshift first.
HAMSTAR
05-21-13, 08:41 PM
Personally, I would go with this plan. You can always buy a new OEM mount later.
Faber
05-22-13, 12:33 PM
For comparison sake, anyone got a pic of a good trans mount installed?
jeremy107
05-22-13, 02:35 PM
I like this idea, I just ordered the trans block. Hope this solves the retarted hard getting into reverse and small rough shifting.
jsnm
05-22-13, 02:42 PM
I have a decent oem trans mount with revshift bushing installed if your interested.
jeremy107
05-22-13, 03:14 PM
Decent shape? As in how many miles on it? Revshift bushings or support block? And how much? Trans block is only 40 went ahead and got that
SevillianSTS
05-22-13, 03:17 PM
Found this on google: http://www.google.com/search?q=revshift+transmission+mount&source=lnms&tbm=isch&sa=X&ei=CBmdUZCaF5er4AO9moCYDQ&ved=0CAcQ_AUoAQ&biw=1242&bih=696#imgrc=u2npMzY0MPpVlM%3A%3B1lc2Nth3vuKH9M%3 Bhttp%253A%252F%252Fi1058.photobucket.com%252Falbu ms%252Ft404%252Fjaysenbaker%252FRevshift%252520tra nsmission%252520mount%252F80a4b563.jpg%3Bhttp%253A %252F%252Fwww.cadillacforums.com%252Fforums%252F20 04-2007-cadillac-cts-v-performance%252F268344-revshift-transmission-mount.html%3B1023%3B612 There is a thread somewhere that revshift posted before and after pictures of the insert installed on a brand new OEM mount. There was no difference in height once the block was installed into the NEW mount.
jeremy107
05-22-13, 03:39 PM
Hmmm nice find there, looks like the block does the exact same thing as a brand new mount costing 100$ more!! Good to know!
Becker
05-22-13, 03:52 PM
that is very informative, i will be inspecting my trans mount tomorrow
FoD
05-22-13, 04:04 PM
My mount looked identical to yours. Revshift block inserted back in October 2012...game changer!
V for victory
05-22-13, 04:30 PM
The RS block completely corrected my issues with going into reverse I was having, my mount didn't look 1/10th as bad as yours, I cant even imagine how your getting into gear with that thing....good luck should be a easy fix and major improvement.
jeremy107
05-22-13, 05:31 PM
There is hope!!
brngrhd
05-25-13, 01:15 PM
Why buy a new mount and a RS insert? Why not just buy the CS mount?
Just went and looked at the pictures again...... I'd fix the leak that saturated the mount in oil and buy a CS mount. The rubber on your mount is so bad installing a RS insert will fix only part of the issue
jonathan2169
05-28-13, 02:45 PM
My 2 cents - just installed the Revshift trans mount insert on Sunday and the difference was immediate. I had limited clearance under jack stands and a jack under the trans and got it done in less than 20min including jacking. Looks like it will not fit and then surprises u when it does. I wish I could say I have this issue often. LOL
Use the grease; made it pretty easy.
