View Full Version : Heads-up on SD armrest port malfunction.
flycaster
05-19-13, 01:58 PM
Had this happen recently and thought you might be interested.
I've been using an iTunes-loaded SD card and redid the card. When replacing it into the port, the card met no resistance and almost totally slipped into the port. Took problem to the dealer, who fixed it. Here's what happened to the port: The unit behind the port is a "snap-together" unit. Apparently it wasn't snapped together too well and it fell away from its supports and in doing so, just wasn't behind the port opening anymore.
Stevo Supremo
05-27-13, 11:26 PM
weird, thanks for the heads up though!:thumbsup: only issue I've had with this is intermittent failure to read device.
flycaster
05-28-13, 11:55 AM
weird, thanks for the heads up though!:thumbs up: only issue I've had with this is intermittent failure to read device.
You're welcome. BTW, I haven't had your problem. CUE works the SD perfectly (Playlists, Genre, Artists).
