: HELP! HELP! Clutch bleeder fell in??
JGeezer
05-18-13, 12:13 PM
I absolutely cannot believe these guys that say they frequently bleed their clutch. After an hour, and after buying a different wrench & socket set, I managed to get the clutch bleed screw loose. Determined to never go through this again, I removed it to at least replace it with a speed bleeder (needed to remove it to get the right size), heard a bit of a clunk and can't find the bleeder. Looking at pics of the Tremec & bell, and trying to look around up there with a dental mirror - it looks like it can fall - and did fall - INTO the bell housing.
108569
Is that possible> How hosed am I? Do I actually have to drop the transmission now - just because that freaking bleed screw is/was about impossible to get to!
Seriously - HELP!!!
[Edit #1]
And while I have your attention, is is reasonable to install the Monster Clutch 36" CTS-V Remote Bleeder without pulling the trans? Never want to go though THIS again...
[Edit #2]
Yep, Monster says you have to pull it, goes all the way into the slave. Are there any that just screw in where the bleeder was?
Not a good day so far...
JGeezer
JGeezer
05-18-13, 12:14 PM
BTW, that's just a pic I found on the net, my car is still assembled, up on jackstands.
darkman
05-18-13, 12:40 PM
What part did you remove?
JGeezer
05-18-13, 01:28 PM
I guess I should of done a lot more research before starting what I THOUGHT should be a simple task. I could see the bleeder rubber cover way up there, took off the cover and got a wrench (socket, actually) on that to loosen it up, assuming it was a normal type bleeder at the end. Given that it was such a PITA to get to, I went ahead and kept unscrewing to take it out and replace it, but fumbling up there blind to finally remove it, it fell.
This thing, as viewed from underneath:
108593
Yeah, I assumed that there was an extension out from the slave with a bleed screw at the end. So what have I done?
darkman
05-18-13, 01:46 PM
I think you have dropped the bleeder tube inside and will have to drop the transmission to retrieve it.
heavymetals
05-18-13, 01:57 PM
You can "fish" for it with a magnet.
A magnet on a telescopic wand will work.
If you get it out, reinstall by using something to make it "stick" in the socket or you will drop it back in.
I would not try to install a remote bleeder this way as I don't think you can torque it enough.
Andringa
05-18-13, 03:57 PM
108593
You can not install a remote bleeder with the trans in the car.
The stock bleeder/tube is a solid piece. Picture a really really tall single piece brake bleeder. When you were loosening what you thought was just the end, you were actually loosening the entire tube, which fell off and into the bell housing.
Don't worry, you aren't the first person to do this.
Good luck fishing... When trying to reinstall it you could try tying a thin string to it so that if you drop it again you can pull it right back out.
JGeezer
05-18-13, 04:58 PM
Thank you all for not laughing me off the forum, and thanks for saying I'm not the first to do this!
Maybe I should just take it as a powerful sign, and go for the remote setup (the 36" monster, I guess), even though I'll need my friendly (and quite nearby) dealer to help. Not quite up to backing out the trans in the home shop. Add to that the embarrassment of getting towed. And then explaining this all to the lady...
Heavymetals - on the "fishing", I guess I'm still confused. I can imagine getting a small magnet on a string up there and into the hole, but when you say "telescoping wand" you need access from the top. How can you get that access with it in the car?
JGeezer
heavymetals
05-18-13, 05:11 PM
JGeezer
Here:http://www.sears.com/shc/s/p_10153_12605_SPM663660514P?ci_src=184425893&ci_sku=SPM663660514&sid=IDx20130125xMPTLSx025
OR
Stick the magnet on a wire snake or a piece of wire you can easily bend to change angles.
A piece of string may work if you happen to "catch it".
Spastic
05-18-13, 10:59 PM
I was trying to bleed my clutch once and dropped a socket in. I managed to get it out with a magnet taped to a coat hanger that I bent into a quarter circle shape. One tip is to not try and snake it from the opening where the bleeder is. There's another opening that I think was about halfway down the side from there, and it gave much easier access.
PISNUOFF
05-19-13, 10:22 AM
Ouch! A little late but a short (3-4") 8mm box wrench and some 1/4" rubber tubing works great for bleeding with the stock bleeder. It's a little had to do your first time but not that bad.
The bleeder will fall out of the threads after only about 1 full turn.
DWF0551
05-20-13, 11:11 AM
I just bled mine also, and I used a gearwrench http://www.gearwrench.com/catalog/wrenches/ratcheting/spline/ and it worked just great. I did notice the whole thing was a bit loose and thought about it dropping in but thought naw they wouldn't design something like that would they? So don't feel to bad it's just luck that it doesn't happen to more of us.
JGeezer
05-20-13, 11:13 AM
To wrap this up:
I actually, incredibly, managed to fish the bleeder out of the lower hole! The Advance auto tool is kind of useless, but the Autozone tool is terrific, I'll advise anybody to pick one up for when you WILL need it, and it's less than ten bucks:
http://www.autozone.com/autozone/accessories/OEM-Lighted-magnetic-pick-up/_/N-25zu?itemIdentifier=617293_0_0_
Light at the end (not helpful this time), but the magnet is shielded so things will ONLY stick to the end, not the sizes, and very flexible and controllable.
Anyway.
So then I secured a socket onto the bleeder and a string, just in case. And then determined that it is just freaking impossible to feed that bleeder back into the top hole in the car, just not enough space to feed it in there.
So I got the great idea to feed a string (actually a safety wire) into that nice middle hole and out of the top hole so I could pull it though that way. Fed it in - and found that the safety wire had invisibly come out of a tiny additional hole above the top hole, and I was screwed all over again.
Sigh. (Not the word or words I used when I realized this had happened.)
My GM service manager Brad is a great guy, he'll put the Monster remote bleeder in as soon as it shows up and I get the V towed up there, and we had a nice time talking big blocks for awhile. My lady is OK, she didn't laugh at me or anything.
JGeezer
2004 CTS-V
2003 Corvette
heavymetals
05-20-13, 01:42 PM
Sounds like two steps back for every one forward.
Welcome to MOD HELL
50 4Ever
05-21-13, 07:59 PM
This is how I maintain my clutches (in the V and Z06); remove reservoir lid, suck out all old black fluid (the black in the fluid is clutch dust by the way), add new DOT 4, put the lid back on the reservoir, pump the clutch about 25 times (this recirculates the fluid). Repeat the above steps until the fluid is clear.
carsaremytoys
05-21-13, 11:47 PM
No worries about sucking too much and having to bleed the system with this method? I love simple maintenance.
Andringa
05-22-13, 12:52 AM
I happen to have an open/unused bottle of brake fluid from last year in the garage. What do you guys think about using it in the clutch? I'm not going to use it for the brakes because I'm sure it's at the wet boiling point after being open for 6 months.
I know brake fluid is relatively cheap and I could just get new stuff, just wondering what people think.
carsaremytoys
05-22-13, 01:02 AM
I'd use it
PISNUOFF
05-22-13, 10:23 AM
I would throw it out. You wouldn't use it on your brakes and the clutch is more sensitive to poor fluid quality.
Andringa
05-22-13, 11:56 AM
I was going to use it, but I ended up finding a new unopened bottle of valvoline dot3/4 on the shelf and used that instead.
50 4Ever
05-22-13, 05:28 PM
No worries about sucking too much and having to bleed the system with this method? I love simple maintenance. No worries. Watch this video http://www.youtube.com/watch?v=gBbsy0LjUvE&feature=player_embedded
