View Full Version : DTS Shut Down
MarkMCDTS
05-16-13, 09:49 AM
Last night my 2006 DTS shut down on me after my low oil light was on for about 2 days. I thought it was a sensor because I just had to oil changed 6 weeks ago. I added 2 quarts of oil and let it sit. The engine would turn over and then conk out after 5 secs. Can anyone give me some insight? Thanks
Eddie39
05-16-13, 09:24 PM
Did you check the oil to see if it was two quarts low before you added the two quarts?
MoistCabbage
05-16-13, 09:52 PM
You assumed it was a sensor, and drive around for 2 days with a low oil warning???
Open hood.
Pull out dipstick.
Wipe.
Reinsert.
Remove.
Check level.
30 seconds, a minute tops?
In any case, it has nothing to do with your stall.
mike5514
05-17-13, 08:14 AM
the engine control module will shut the engine down with a anti theft or throttle actuator control problem.
So far I have not found a correlation between low oil and a engine shutdown although i have read of people that have experienced it.
It would seem to me that a modern engine would shut down just to save itself. Mike
