: antenna 1983 Cadillac Fleetwood Brougham Coupe Wanted new or used
David Biarritz
05-15-13, 08:34 AM
My antenna will not come down even so the motor is running. The only way I can remove it, is to cut the mast to allow it out the bottom of the fender.
David Biarritz
05-21-13, 08:22 PM
I have now removed the antenna by removing the mast.
I removed all the retainer clips and drilled out the rivets and found that the mast tail was broken in the tube.
I managed to do all this through the access hole, bottom of the fender.
Removed everything with minimal damage.
Any body out there with a used antenna or mast for sale ?
ckulibert
05-30-13, 12:04 AM
Call Roger at 715-377-9328. He should have one.
