: Starter Heat Wrap ?
05-14-13, 10:27 AM
My starter was replaced recently. What is the best method to protect it ? Wrap it with heat wrap, or I know they have the heat "bag" that goes over it ? Where do you recommend buying from ? I've seen them at AutoZone and so does Summit Racing. Does either option require removing the starter ? Thanks.
Answering some of my questions =) I found a few on Summit; should I get the one with metal straps, or the Velcro ?
05-14-13, 11:21 AM
I did the velcro one from summit,cut it to the size of the starter,put it on and also ran a few lines of safety wire around it to help hold it on as well.
05-15-13, 11:20 AM
Heat wrap is a must for longevity
05-15-13, 07:54 PM
Ditto...heat wrap it, got mine at pep boys for like $6.00...that ignition lead will melt again if you don't...
05-15-13, 09:47 PM
All done. I bought the DEI wrap but was not able to use the velcro since I wrapped the motor and the solenoid separately. I was going to wrap the whole starter in one wrap but I was nervous about the metallic wrap and the end of the main power cable that attaches to the end of the solenoid.
