View Full Version : Wth!!!!!!! Driveshaft? Need help quick!!!
silver02ta
05-13-13, 08:36 PM
How in the world does this propeller drive shaft come out? Ive unbolted all the bolts but it wont come apart? I tried prying it apart but nothing...am I not puttn enough a$$ into it?
dannyquest
05-13-13, 08:49 PM
silver02ta, Do you mean the drive shaft to the rear diff. Only four bolts on each end. I have had mine out once, easy. Danny
silver02ta
05-13-13, 08:51 PM
im trying to take out my trans....I just need it out of the way...I only unbolted the front section that bolts into the tailshaft
dannyquest
05-13-13, 09:05 PM
silver02ta, You must unbolt the other end at the diff. the drive shaft should drop down. Danny
orange57
05-13-13, 09:42 PM
You may be able to just unbolt the carrier bearing mount, and that may be enough. But it would be better to remove the shaft completely. I don't think you want to bend that bearing too much. I removed it completely. Torque specs are in my thread.
silver02ta
05-13-13, 09:54 PM
I removed the carrier bearing mount too and it still wont come apart from trans??
orange57
05-14-13, 01:04 AM
Get a bigger pry bar. If I remember correctly, there are metal spacer tubes in the rubber donuts that the bolts go thru. When torqued down they are pretty much press fit into the trans prop. Take some pics and post them and I can tell you if I see anything you missed.
silver02ta
05-14-13, 04:07 PM
Finally got it.... ughh
dannyquest
05-14-13, 06:51 PM
silver02ta, How big a pry bar did you use. Danny
silver02ta
05-14-13, 07:14 PM
I used a ball joint separator lol
