I doubt it, Calipers should not need a rebuild unless tons of miles or you burn up the piston seals doing track or racing. I have rebuilt many motorcycle calipers but only after 50K miles or so an/or real racing.
Calipers should last you years and years without a rebuild. There is no need to rebuild them unless you get uneven pad wear showing a hung up piston or it starts leaking. Give yourself a break and do something else on the car.
i've burned up the dust boots on my cars routinely at track days and rebuild the calipers every year. It's a royal PITA. Unless you've done an aggressive track day, you shouldn't need to rebuild them without other issues going on (hanging, leaking, etc). You can examine the dust boots when you pull out the pads.
I suggest getting some BrakeClean, and spraying it all over the caliper pistons if your doing lots of track days when you change pads. That and a toothbrush to scrub the junk out. I always do that with my motorcycles that use multiple opposed pistons calipers. That will really help the pistons from getting gunked up and possibly drag or seize. Its nasty how much gunk gets in that area.
Real race calipers don't have dust boots just for that reason. My Alcons in my Audi did not have them. THey get toasted and can freeze up the calpier pistons.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
