View Full Version : 2005 Low Beam fuse allways melt (20a) right side
pilot188
05-12-13, 04:05 AM
Hi everybody
have somebody an idea, what I can check?
first:
My right side low beam fuse allways melt. I replace the HID Bulb allready. High beam, turn light etc. are allready working
second:
I buy a used head lamp, but the connector of the 2005 -2007 is different to the later series
So I have two questions
1) which parts must be replaced to cover the melt of the fuse and where I can get this?
2) Is there a possibility to convert the connector of a 2005 SRX to fit on the head light from the later series?
Hope, somebody can help
Uwe
pilot188
05-12-13, 02:09 PM
Only possible causes for my understanding
Ballast and cable between beamer and ballast
does any valeo lad5g (12 pin) ballast fit or is there a different version for cadillac?
glake89
05-12-13, 02:22 PM
If the right side fuse keeps blowing, either the ballast is bad or you have a short to ground in the wire. Unplug the ballast and put in a new fuse. If it doesn't blow, the ballast is bad.
pilot188
05-12-13, 03:01 PM
When I unplug the head lamp, the fuse don't blow away
So for me, it sounds like the ballast.
Does any valeo lad5g (12 Pin) fit?
There are a lot off in the bay, also in europe
glake89
05-12-13, 04:38 PM
Here is the part # and description for an '05 from the SM-
OEM: 15373535
Service: 15373535
Description: 12-Way F GT 150 280 Series Sealed (GY)
Hope this helps.
