View Full Version : My friends '89 Cadillac Brougham d'Elegance blower won't blow?
CandyLacBrome
05-11-13, 04:31 PM
Compressor good, new blower motor, fuses good, just no power to the fan. What gives?
cadillac kevin
05-11-13, 04:55 PM
I'd guess bad ground, bad fan speed module, or bad ECC head (in that order).
j2rossit
05-11-13, 05:03 PM
The Tan wire feeding the blower should be hot at all times. Check to make sure it's getting voltage.
If it is, then you can run a wire from the from the blower motor case to a good ground and double check the motor starts to turn (be warned that it will spark since the blower is getting 12V already.
If the motor starts, then the resistor module is highly suspect (The unit mounted in the air plenum directly beside the blower motor). It should be grounded to the center of the firewall.
SafariOne
05-11-13, 06:06 PM
There is also a fusible link in the blower feed.
CandyLacBrome
05-11-13, 06:06 PM
Thanks for replying guys, I'm going to let my friend know. :)
