: 2002 Escalade Ext Daytime driving lights?
Pitbull14218
05-11-13, 03:56 PM
Hi my passenger daytime running lights went out, I'd like to replace it with something that isn't so yellow looking. I plan to eventually install some HIDs. Any reccommendations? What type of bulbs are they? They are not my headlights by the way, they are a smaller light.
Thanks
YoshiMan
05-11-13, 05:45 PM
The Escalade DRLs run at a pretty high voltage (somewhere around 14.4 volts) so they require their own special bulbs that can handle it, which are the 4114 bulbs if i'm not mistaken?
The chances are good that your DRL sockets will be toast as well, as the bulbs run VERY hot and the socket will likely break apart when you go to change it You can buy new ones on Rockauto.com for less than $10 apeice
I replaced mine with a set of LED bulbs, as they get rid of that yellow color (more of a bright white now) and create little to no heat. The only ones i could find that specified that they could handle 14.4 volts were on CarID.com, but maybe someone else on here has better experience with off the shelf LED bulbs?
the cadillac man
05-11-13, 06:13 PM
I got my LEDs from superbrightleds website had them for over two years no problems(I tried slyvania silver stars big mistake as it hazed my housings before I went led)
Hid bulbs would not work in the drl spot as there is no bulb for the socket
Pitbull14218
05-11-13, 10:45 PM
Anyone make any threads on changing them to LED?
the cadillac man
05-12-13, 01:48 AM
Replacing the standard bulbs to the LEDs like I got is no different then changing a regular bulb
Pitbull14218
05-12-13, 09:27 AM
Oh ok, i thought you had to customize it to install them, you have any pictures of them installed what they look like?
The ones at carid seem to be $50 for daytime running lights?
Then at superbrightleds non say for 14.4 volts?
the cadillac man
05-12-13, 01:28 PM
I have been using the ones from superbrightleds without a problem so far
FYI the price on the site(not carid) is for one bulb but they are worth the price
If you can pm me your email address and I can send the pics
The color is close to the hid bulbs(which I like better then yellow)
Pitbull14218
05-12-13, 03:24 PM
Ok, im also interested in HIDs, how big of a problem is it since my 02 doesnt have projector housings? Id like to not blind people, also anyone reccommend a kit?
the cadillac man
05-12-13, 05:00 PM
I wouldn't recommend putting a kit in the headlights on a 02 fog lights are ok if aimed right
The 03-06 have different housings that are designed to work with the factory hids
I got my kits from here www.kensun.com
Unless you get projection housings for the headlights you will blind oncoming traffic
The fog lights are low enough to where you won't have to worry as long as they ain't pointed up towards the sky
Pitbull14218
05-12-13, 07:11 PM
What about different bulbs to make them not yellow but brighter?
the cadillac man
05-12-13, 09:52 PM
I tried the slyvania silver-stars and they caused the housings to haze so the best choice is led(not that most people pay attention to the drls anyway they don't in my area for sure)
Plus they aren't required in the us only Canada
Pitbull14218
05-12-13, 10:07 PM
Do they make LED headlights that are bright enough to replace my stock low beams? Any reccommendations
the cadillac man
05-12-13, 11:17 PM
Nope I have yet to see any if you want the hid look get some Phillips crystal vision bulbs they are a nix white light(smilier to hids) without the glare you would get from hids in the non hid housings(which is not good for other drivers)
Pitbull14218
05-16-13, 07:22 AM
I bought some LED DRLs, and a 6,000k HID kit, I post before and after pics when I get them island install them. I hope it's not going to blind other people driving, otherwise I might paint some of the reflectors black or somehing to make it not reflect as much. I heard even the 03-06 headlight made for HIDs don't do a get job keeping people from being blinded.
the cadillac man
05-16-13, 02:18 PM
That claim is false they do a much better job then say a non hid housing does(they have a cut off around the belt line of most cars which makes it better for both me and the other drivers)I have my headlights aimed right and have yet to get flashed by oncoming drivers
Putting hids in a 02 escalade housing will cause major glare and will dazzle other drivers
Before you do any painting I would get the proper housings and the proper ballast and bulbs they ain't that hard to swap out
Pitbull14218
05-16-13, 10:02 PM
I might just try to install some projectors in the stock housings some bow. Although both my headlights have the mounting rod holes cracked... One is being held in with wire. They're too bright, I didn't aim then yet either
http://i102.photobucket.com/albums/m81/pitbull14218/null.jpg
the cadillac man
05-16-13, 10:37 PM
That is some major glare(NOT GOOD)
mikedyk43
05-17-13, 12:31 AM
Just a crappy camera, not so bad...
the cadillac man
05-17-13, 02:37 AM
True a camera will make it look worser then it is but the point still stands hids in a non hid housing on low beams is risky
