: 05 V Sunroof issue
05-10-13, 10:52 AM
Noticed yesterday when I shut Driver door, the front of the sunroof lift up abt. an inch or 2. It opens and closes fine. is this normal?
Appreciate any/all replies
05-10-13, 02:42 PM
Mine does that also, doesnt seem like it moves that much tho. I dont have any leaks or anything so I assume alittle movement is normal as the air pressure changes by closing the door. Id say if it doesnt leak then its probably normal.
05-10-13, 05:59 PM
Same on my 05...it doesn't leak water, but you can hear wind..I'm assuming its the switch..I think there's a TSB on it as well..
05-10-13, 08:36 PM
Ok thanks. Will keep eye on it
05-10-13, 10:55 PM
See attached.
