: Air ride compressor pressure
jetskiracer
05-07-13, 05:32 PM
Troubleshooting the rear air suspension on a 2004 Escalade. The shocks do not raise the vehicle at all. The compressor was replaced a year or 2 ago. The compressor runs and I cannot find an air leak. I noticed I can hold my finger over the compressor air outlet and stop the air. Does this mean the compressor is not putting out enough pressure to fill the shocks?
the cadillac man
05-07-13, 07:36 PM
More then likely its the exhaust valve solenoid that has failed and the compressor needs replacing
90limited
05-07-13, 11:27 PM
I think I saw somewhere the compressor has a Maximum Air Pressure (psi) of 165... if the unit comes on when you start the truck, the exhaust soleniod is not an issue. If you have to jump the relay to get the unit to come on then it is an issue.
the cadillac man
05-08-13, 12:46 AM
the service manual shows 187.8 as the max psi that the pressure sensor reads
If it is bad it could cause the system to vent out the air but the compressor would have to be replaced as the sensor is on the dryer of the compressor
If you can get the error codes I can find out what it is in my gm service manual
jetskiracer
05-08-13, 05:32 PM
I jacked the rear end up and found a tear in the rubber on the shock. Couldn't see it with the shock compressed.
Called the dealer and the serviceman was like "Oh Wow, GM must be impressed with their shocks" $670 each $1500 installed.
Looks like I need to check out the Arnott shocks.
Which model? Want to keep the autoride self-leveling for towing.
New Bilstein/Arnott Rear Air Shock Kit (pair) AS-2127 for $369 or
Remanufactured O.E.M. Electronic Rear Air Shocks (sold in pairs) AS-2411 for $379
Also, Is there a current promotion code for a discount?
the cadillac man
05-08-13, 05:40 PM
You want to get the remanufactured oem shocks to retain the stocks auto ride system
jetskiracer
05-08-13, 05:46 PM
Wow, that was quick. Thanks. Wasn't sure if the Bilstein set would of worked, the description on their website isn't clear.
the cadillac man
05-08-13, 06:29 PM
I have the iPhone app for the forum is why
