: Road Course impression
the blur
05-07-13, 12:55 AM
My 1st outing: All stock. No alignment, no nothing. It's certainly not a Corvette in terms of handling, but the car holds it's own on the road course. My Corvette definitely handled better. But the V is no slouch. I ran in comp mode, in regular mode, tour shock setting, and sport shock setting. The car really shines in comp mode with the increased steering "ratio", or the lowered amount of power assist.
I never got the car loose, sometimes a mild push. I don't think I was into the stability system, as I would have felt it kicking in. The factory tires are more impressive on the track than on the street. Once the tires heated up, they stuck very well. Certainly not a race tire, but more than enough stick for the car in stock form.
The motor is simply amazing, in every gear, in every RPM range. The car just pulls and pulls. I would never do anything to the motor. No reason to void the warranty.
The bad, (you knew this was coming).
The base level seats are beyond pathetic. I brought mine used, so I couldn't get the Recaro's. My arms & legs hurt from holding myself in the seat. The Recaros look like a nice between the base seats, and a true race seat. However, on the 400 mile drive, the base seats are very comfy.
The gas tank is way too small. 6-7 MPG on the road course. I was refilling fuel way too often.
Another thing is head room. I have just enough head room with a helmet on. Actually not enough. I'd like more clearance for bumps. And the Recaro's look higher than the regular seats. So I'm not sure the Recaro's are the answer for head room.
All in all, I really love the car. It's perfect for a daily driver, and a weekend track event.
Chrispy
05-07-13, 09:41 AM
Nice feedback :) I bought the base seats as well as I was wary of the racket / rocking that often comes from the Recaros. I'm hitting a road course in the next three weeks and will provide feedback afterwards as well.
Were you able to pull out the seatbelt all the way and have it retract/lock you in? What tire pressure did you run? I heard 45psi front and 40psi rear is a good starting point.
Cheers
Chris
CJCTSV
05-07-13, 10:17 AM
Cheers
Chris
Sweet Jesus, where did you hear that?
Don't run that high cold, you'll potentially seriously do harm to your tires and maybe yourself.
the blur
05-07-13, 10:24 AM
Nice feedback :) Were you able to pull out the seatbelt all the way and have it retract/lock you in? What tire pressure did you run? I heard 45psi front and 40psi rear is a good starting point.CheersChris
The seat belt, I pulled on it upwards to tighten it up as much as possible. Not sure if it locked on track. 45-40 are hot pressures, not cold. I ran 3 lbs higher in the front, not 5. While I ran high pressures, because I didn't want to destroy my tires, it probably would have worked better with slightly lower pressures. But you can run 50psi according to the side wall. I was very happy with the tire wear, or lack of, on track. I did 200 track miles, and had track rubber stuck to my tires after every session, but once the track rubber came off, you can't really see any significant tire ware. If I really wanted too, I could have played with pressures all weekend long. But the fact is, I just relaxed and enjoyed the car.
M5eater
05-07-13, 10:38 AM
agreed. Infact, I have 0 room with a helmet, I opted for a sunroof delete with the blue one, but even with that I'm ~ .5-1" away from touching the headliner. With a sunroof I had to have it open and turn a bit sideways to fit.
Disappointing to say the least for a midsize.
Chrispy
05-07-13, 11:51 AM
Hot not cold :)
the blur
05-07-13, 11:51 AM
Read the sidewall. you can run that high cold.
Chrispy
05-07-13, 12:04 PM
Yup, I'm talking as a starting point though :)
IGraf
05-07-13, 12:52 PM
Great review of the track day experience - thank you the blur.
I'm greatly interested in additional input and experiences with tire pressure. I ran the Wagon at the Ridge (WA) a week ago and did experience excessive rolling over on the sidewalls on both front tires. We started with 36 psi (cold) and increased pressure for each run, ending up at 45 psi (hot). Even at that level, the fronts were rolling over onto the side wall by about 1/2 inch.
Interestingly, the Wagon came with Michelin Pilot Sport, not the PS2 most seem to have on their new cars. At this rate of sidewall abuse, I'll have the opportunity to switch to PSS after a couple more track days -)
Any further input/experience with proper tire pressure for the track is greatly appreciated.
Having said that, the car is quite impressive at the track!
thebigjimsho
05-07-13, 01:29 PM
I, as well as others, have been trumpeting for about 3 years that the front tire pressures need to be bumped up. I learned this on my very first track day. You'll scuff up the outer corners in just a couple of sessions. But, if you do, the PS2s stick and really shine...
As for base seats, I wouldn't want them for a run to the supermarket. Forget anything with turns. The seats in the V1 weren't great, but worlds better than the base seats. And in the V1, I was always adjusting my body around after every corner.
The Recaros let you focus on one thing: driving. Period.
flyingv
05-07-13, 02:29 PM
Hot tire pressures have a lot to do with driving style and the amount you push the car. On toyo r888's for the Cadillac challenge we start at 32 psi cold and have to lower from there sometimes.
Just this last weekend at Willow Springs this topic came up in the driver's meeting for HPDE3 and the head instructor was looking for all of us, to keep pressures below 40 hot regardless of tire type.
I agree lower pressures will cause more wear on the shoulder of the tire, but Is anyone expecting to run around a race track without wearing out their tires.....
High pressures will cause the tire to loss massive amounts of grip on the edges of the tire as the tire balloons in the center, and make the car much harder to drive fast safely (ie, less tire is in contact with the track surface)
thebigjimsho
05-07-13, 03:00 PM
I've never noticed a loss in handling with the PS2s. Also, I spoke with a Michelin engineer at a Cadillac Driving Lab event and asked him about the scrubbing and running higher pressures. It's what he recommended as well...
flyingv
05-07-13, 03:19 PM
I wouldn't consider the Cadillac driving lab the cutting edge development arena for this car. I would consider it a safe environment to excite people about the cars without damaging them or pushing them to hard (not in GM's best interest to have a bunch of people with little to no experience wad them up at the race track)
I would argue that the Cadillac challenge is an arena where the cars are being pushed above and beyond what GM ever intended them to do. We are actually measuring the benefits of our modifications in a real world scenario.
I also remember you arguing against the need for the differential cooler based on your experience, yet every competitive car in the challenge running decent tires has experienced the problem and had to add one.
Just my 2 cents.
IGraf
05-07-13, 03:24 PM
In my experience, it's not so much about keeping the tires from wearing out, but about keeping them from rolling over so far that I started to take off the lettering on the side wall. And yes, I may have pushed the car a bit ... just a little bit -)
thebigjimsho
05-07-13, 05:02 PM
Just my 2 cents.
Wow, you are wrong on all counts.
I've never argued against a diff cooler. I WANTED a diff cooler on my V, just not at crazy prices. I did say that having fresh fluid before a track day seemed to minimize frequency of the Hot Diff Light.
As for the Driving Lab, I only said I talked to an engineer there. I didn't refer to any driving there. My real world experience was with MY V being able to do whatever I wanted.
Also, the first one I went to in Nov '08, they let you drive as fast as you wanted as long as the instructor allowed. And he allowed me. You can ask OldRoadDawg, he was there...
the blur
05-07-13, 10:59 PM
I ran a 1995 Corvette for many years, thousands of track miles. There was no diff temperature probe. So I never knew how hot it got :) problem solved.
I'd like to know the temperature range of the diff while running, and what temp causes the warning light.
thebigjimsho
05-07-13, 11:24 PM
I know, I wish I had an idea. Since it happened a couple times at the end of a session, I wonder if its conservative and if I could've finished without issue...
Chrispy
05-08-13, 09:31 AM
I can't remember the temp offhand but it's listed here on the forum somewhere if you search.
quikag
05-08-13, 10:57 AM
I had a horrible experience with my first and only track outing with my '12 V automatic. I boiled the brake fluid, chunked the stock brake pads, and lost all pedal pressure and slid off the track within 10 minutes of the first session. I threw it into a spin saving the car from damage.
Of course, I track a ZR1, so I don't know how to drive easy on the track which contributed to the problem. If you are going to push the V on the track at anything over 50%, you need at least DOT 4 brake fluid and track pads IMHO.
Check out 5:30 of this video:
http://www.youtube.com/watch?v=XmVEabf_Mvk
IGraf
05-08-13, 01:05 PM
[/URL]
I changed to racing brake fluid as is stated in the Owner Manual (section 9-6: "For competitive driving, it is recommended that the brake fluid be replaced with a high performance brake fluid that has a dry boiling point greater than 279C (534F). After conversion to the high performance brake fluid, follow the brake fluid service recommendations outlined by the fluid manufacturer.")
While the stock brake pads did smoke and smell extensively after the first session, they returned to normal after that and performed well.
I did experience the dreaded diff temperature warning after roughly 20 min each session. That is truly the one serious concern/disappointment so far that may prevent me from using the V for extended track day duty.
baabootoo
05-08-13, 01:58 PM
The front belts don't lock after pulling them out, just the rears. I know this after putting a child seat in recently many, many times. :) I read that someone twisted the front, and then it at least locked the lap belt. You can bolt a 5-point in, and have it pass tech, very easily. Since this differential temperature seems so sporadic, I'd get a laser temp sensor and check it out first. Maybe some sensors are bad/off.
jenlain
05-08-13, 02:03 PM
Motul RBF600 fluid and hawk dtc70 pads have been a good combo for me at the track.
I switched to redline fluid in the diff (stock weight) and make sure to change it after every 3-4 track days. I get the temp warning consistently, but fresh fluid should resist heat a bit better.
I'm running stock tires and stock drivetrain.
miamictsv
05-09-13, 09:33 AM
I also hit the track last year for a few laps and the stock seats on my 09 V are the worst ever i have sat on a track. $18K Mazda 3 have better supporting seats then the junk in my car. I will not hit the track with these seats again as the pleasure of driving is simply zero if i have to hold for dear life in each corner. I also bought it used so i had no choice.
thebigjimsho
05-09-13, 06:52 PM
Yikes. I know I keep trumpeting the Recaros and lambaste the base seats. But it sucks that it has soured your enjoyment of the V...
jb_bgg
05-10-13, 04:35 PM
Dumb thermoswitch triggers the diff overheat message somewhere between 275-300*. Normal driving in my manual, diff oil temp averages about 125 - 150 depending on ambient and how long a drive. After a 20-25 minute track session @ Auto Club in Fontana, 90 degree ambient, my return oil temp post HX maxed out @ 180 or so.
the blur
05-10-13, 04:38 PM
Good synthetic oil is fine till 400F. I wouldn't get too worried. I'd switch to heavier gear oil before doing a diff cooler. And considering I'm not racing, I'd lift off the throttle a lap, give some point-bys, and then get back on it.
the blur
09-16-13, 01:22 AM
I'm hitting the track again with the factory tires. Have you guys been playing with tire pressures ?
thebigjimsho
09-16-13, 07:55 AM
I still say 37-39 hot on the rear, 41-43 hot on the front...
Arca500
09-23-13, 12:37 AM
Head room is tough in a V it seems. I'm 6'2 and with a helmet, I had to drive with my head cocked just slightly. It bothered me until the adrenaline kicked in, and then, nothing else mattered.
the blur
09-23-13, 07:58 AM
I run a low profile helmet. So helmets just have too much on top. I'm also 6'2", and I have about 1" of clearance. I'm also assuming you have the big sunroof. As far as pressures, I run very high pressures, and the car sticks like glue.
Rule12b
09-27-13, 01:44 AM
Diff overheat is a weakspot on the car. I just ran the Silver State Classic and 40 minutes of sustained 120mph cruise control (yeah, I used it) got me diff overheat. In a straight line more or less. Now, I do run 335/30/18 rears, but still, unless I had a bad temp sender (possible), that's pathetic.
the blur
09-27-13, 02:03 AM
Diff overheat is a weakspot on the car. I just ran the Silver State Classic and 40 minutes of sustained 120mph cruise control (yeah, I used it) got me diff overheat. In a straight line more or less. Now, I do run 335/30/18 rears, but still, unless I had a bad temp sender (possible), that's pathetic. What did we do before cars had diff temperature sensors ??
thebigjimsho
09-27-13, 09:38 PM
Burn, baby burn!
soon to V
11-16-13, 09:05 PM
I track often and hard, and I've designed my own (track day) diff cooler (didn't care for what was out there). I have a temp prob on my car and chart diff temps (rise and fall) so I can monitor the performance of my cooler. The diff overheat temp comes on right at 320 degrees. I run Royal Purple synthetic with a slip additive. My experience (from testing) is that the diff will make some noise after you hit 320 - that is after it cools down. I suspect its the slip additive that is giving up, but I'm guessing. Changing the fluid always solves that noise issue. Of course, not overheating is key to fun! My cooler design is fanless and hidden, but will run a full day of 25 minute sessions (this with about 600 wheel HP and Hoosiers - aka: harder to keep cool). I have a slightly used one I will sell for $500 (find one cheaper) if someone wants to provide me feedback on its use (but only 1). mike@v2vdesigns.net
PS I agree with BigJim on stock tire pressures. Hoosier tech advises me to end at 49 all around on my Hoosiers. Said for what its worth.
