View Full Version : home link
C "T" ess
05-06-13, 04:22 PM
The operating range of my Home Link is very short. This is a 2012 Coupe. I just about have to get to the driveway before it will work. On my 2010 it was also short but not this bad. Has anyone figured a way to increase the operating range.
arw1510
05-06-13, 05:45 PM
How long is your driveway? mine works from 200 ft away at the end of my driveway no problem
gohawks63
05-06-13, 05:57 PM
Ditto that.
Paul_Rider
05-06-13, 07:54 PM
Same here .... Actually it works better than the actual remote.
RAB
05-06-13, 07:56 PM
Same here - mine works from at least 200 feet away.
C "T" ess, maybe your Home Link unit is faulty, or something is affecting its transmitting range.
like2drive
05-06-13, 08:52 PM
I have tried to program mine without success. Still using the remote...
arw1510
05-06-13, 09:33 PM
Every car I've had with the universal one seems awkward to program but you really have to follow the instructions carefully and make sure you hit the learn button on the garage door opener in the correct time and then it should work
gohawks63
05-06-13, 09:47 PM
Correct. It is time sensitive once you hit the LEARN button on the opener you have about 30 seconds to complete the steps. If you don't work fast you have to start over.
C "T" ess
05-07-13, 08:50 AM
My driveway is about 30' long and my opener is old enough that it does not have a learn button but the hand held remote works from at least 300' away. This continues to baffle me.
HurstGN
05-13-13, 12:50 PM
Could it be the HomeLink signal is being deflected up and away by the moat? hehehe
like2drive
05-15-13, 10:03 AM
Found the learn button on the garage door opener - was behind the plastic cover. Now, I'm using my homelink for the first time!!
