: 96 Fleetwood Brougham
05-05-13, 12:37 PM
Need help, factory sun roof has started leaking. :ill: What's the best way to fix problem? :confused:
05-05-13, 01:04 PM
Clear the drains.
Not sure where they exit on the Fleetwood, but the grommets at the end if the tubes is usually where all the debris is.
05-05-13, 01:22 PM
yep, clean the drains first of dirt buildup, we just run air through them if you have a compressor, if there clean and still leaking, replace the gasket
05-05-13, 03:12 PM
If you use compressed air, use LOW pressure.
