View Full Version : Steering wheel rub issue?
Cadsrfun
05-04-13, 12:43 PM
I seem to have some sort of an audible steering wheel to column rub when I turn the wheel. The vehicle is a 2010 ESV Platinum however this issue would probably pertain to all Escalade models. I looked between the wheel and column an there looks to be a sufficient gap. Has anybody else had this issue? It might be internal at the steering wheel to column interface. I'm hoping its not something called the clock spring which allows the steering wheel to turn while still making up the internal electrical connections. I done a search and came up short except for one guy complaining about Escalades and noting this is one of a lot of issues. Any help would be appreciated.
MrHolland
05-04-13, 01:16 PM
2010 Platinum Shorty, haven't noticed it on mine.
2kflhr
05-04-13, 07:17 PM
I've noticed this slight noise when turning in my mine on several occasions.
SpyShops NY
05-04-13, 09:14 PM
Me also I had it on my 2003 ESV and when its cold outside the same on my 2008 when I go to the dealer I am going to ask the good old boys what this is.
Cadillac Cust Svc
05-04-13, 11:19 PM
Hello Cadsrfun,
I am sorry your vehicle seems to have an issue with its steering wheel. Is taking your vehicle to the dealership something you would consider because we rely on our dealerships for their technical expertise. Please let me know if you want further assistance. If you private message me with your concerns and contact information, VIN and current mileage, I am more than happy to explore any options.
Sincerely,
Laura M.
Cadillac Customer Service
Cadsrfun
05-05-13, 02:52 PM
Please post the results of what they say... Thanks
Cadillac Cust Svc
05-05-13, 02:54 PM
Hello 2kflhr,
If you would like assistance with this issue please let me know. If you private message me with your contact information, VIN and current mileage, I am more than happy to look into this issue for you and explore our options from there.
Sincerely,
Laura M.
wwceaton
05-05-13, 05:00 PM
I would love to help but every time i fix this problem it is always something diffrent every time. Could be the clockspring, the plastic shrouds rubing, steering columb bearings, lower septer shaft going through the fire wall rubbing. So with out seeing it first hand i am only giving out the most common problems. Good luck.
Cadsrfun
05-06-13, 12:47 AM
Thanks for the options. The plastic shrouds sounds like the easiest thing to check out first. The rubbing seems close to the steering wheel so I think bearings and lower shaft are not likely.
2kflhr
05-06-13, 08:47 PM
Hello 2kflhr,
Sincerely,
Laura M.
Cadillac Customer Service Thank you, I plan to go by the dealer this week to have them provide the key for my wheel lug locks so I will mention it then. I I don't get it resolved I'll get back with you. Thanks Again!
The plastic shrouds sounds like the easiest thing to check out first. The rubbing seems close to the steering wheel so I think bearings and lower shaft are not likely. Yup, same here
Cadillac Cust Svc
05-06-13, 10:56 PM
Yup, same here
Thank you for getting back with me 2kflhr. Keep me updated after your dealership visit.
Sincerely,
Laura M.
