View Full Version : Valentine V1 hardwire
sdm100
05-04-13, 09:10 AM
Want to hardwire my Valentine V1. Saw there is a fuse panel on the drivers side of the dash. Many of the fuse locations are not used. Question is are they hot and can one insert a fuse in an unused location and get the power needed or do i have to tap one of the exisitng used fuses. Really easy location to use as I can run the wire right down the drivers side pilar to the box. Appreciate the help
mikesul
05-04-13, 12:33 PM
Check search as this has been discussed, pictures available in the answers.
flycaster
05-04-13, 03:39 PM
Here you go: Fuses 17 and 18, power flows on/off with ignition on/off. Take a look at this thread for info and pics: http://www.cadillacforums.com/forums/cadillac-ats-technical-discussion-forum/286276-need-radar-instillation-info-where-diy.html
When I did it, my only concern was that the wire would be difficult to squeeze between the dash and the pillar. This concern turned out to be a no-brainer. Just push the wire in using a flat tool...really easy. Good luck.
thebigjimsho
05-06-13, 02:19 PM
In my Vs, I just tapped into the dome light. Never an issue.
