: dyno results II
roo6.2
05-04-13, 02:01 AM
Went back to the dyno again tonight to try to add more timing to get hp more inline with torque. Succeed but ended up putting the old tune back in to be safe because the stock fuel system seemed to be on edge at high rpms at that point with the E85. We didn't notice it on the dyno but once we got it out on the road it was starting to lean out a bit as we went through the gears so I'll leave it at the 620hp/655tq tune until I can get a boost a pump in.
http://img822.imageshack.us/img822/8021/ctsvdyno666hp668tq.png
Final results for the night were 666HP/668TQ
Mods:
E85
Airaid CAI
2.5/9.17 pulley
ID850 injectors
2013CTSV
05-04-13, 02:10 AM
Just awesome, absolutely awesome.
V locity
05-04-13, 07:44 AM
That is awesome!
Throw some DRs on that bad boy & you have a 10.5 @ the local 1320 ;)
Ya know, there's a movement right now to get these cars over to a true flex fuel car with a tune tat adjusts to the alcohol sensor. Good times for sure!
roo6.2
05-04-13, 09:52 AM
DRs were the first mod after I purchased the car. I usually just leave those on all summer :)
Yeah I'm planning to go back to the track here soon. I was there a few weeks ago before the lower pulley and E85. The track is around 2,200 ft elevation which is about 1,000 ft above were I live so I'm not sure if that caused it or something else but I threw a check engine light (P1101) on the first pass and it was bleeding boost off to around 10 psi. Never had the issue before but it still managed a 12.1 @ 116
We disabled the p-valve after the lower pulley install to make sure that didn't happen again. Boost is holding steady now.
http://img822.imageshack.us/img822/3704/ctsv121116.png
1.8 60ft's weren't great but I can improve on those next time I'm there. I wasn't really warming up the DRs very much
wait4me
05-04-13, 10:39 AM
13.1 air fuel at wide open throttle is a bit scary.... Even for a Non supercharged car......
roo6.2
05-04-13, 10:55 AM
Agreed
Purevil
05-08-13, 09:57 AM
Man would this make me the happiest kid around!!! (And I am sure I'm not the only...)
