: Bagged 2cd gen CTS need second opinion about wheel sizing.. 20x10's and 20x9's
gmax111
05-03-13, 02:19 PM
Finished bagging my CTS last weekend.. Accuair, All 3/8ths 304 stainless steel tubing, dual viair 444c compressors, 5 gal powder coated aluminum tank.
http://imageshack.us/a/img10/4993/42060252695165067698817.jpg
http://imageshack.us/a/img211/3743/40698952876496716232392.jpg
http://imageshack.us/a/img202/9042/img1216wx.jpg
http://imageshack.us/a/img838/9545/56240552734941730387835.jpg
http://imageshack.us/a/img811/334/16419753058839031331412.jpg
http://imageshack.us/a/img707/5250/28425753058846697997320.jpg
http://imageshack.us/a/img803/1416/94509853058843364664320.jpg
Ok so just to clear some things up for those who don't know, before the flaming begins. :tisk:
The ride quality is amazing, air is better than factory coils/springs.
THE CAR DOES NOT HOP, nor does it have any bounce going down the road..
Airbags are completely adjustable so turning and speed bumps are not an issue..
I will be going lower by raising the shock/strut towers or custom sized aftermarket shock/struts.. And if need be tubbing the wheel wells later on down the road.
I have been doing adjustable suspension for years and this is a very dependable setup, absolutely no air leaks, but my question is to those guys running 10inch wide rims in the rear.. Currently the factory 18inch rims/tires clear the inside of the rear fenders by .75inch.. The rims I want to order are 20x10 with offset/et of +45.
This is factory 18" rim/tire compared to the setup I want to run.
http://imageshack.us/a/img706/1023/tiresh.png
Courtesy of http://www.rimsntires.com/specs.jsp
Im not set on a 265/30R20 just used that for the comparison purposes.. 275 or 285 sounds better but I will test fit clearance before purchasing..
The front setup is 20x9 with offset/et of +35..
According to my measurements using the tool and specs in the image above the 20x9's and 20x10's will both clear the inside of the fender by .1 inch. Which has me a little nervous because the new rims/tires could be a little different than they state.. Also not sure how accurate that wheel measurement tool is..
Anyone see issues with my measurements or have opinions regarding the new setup clearing the inner fender..?? I'm hoping for real life experience with a similar wheel setup. Do you think your 20x10s would clear the inner fender if it was bagged?
Also take into consideration that the wheels camber in as the car is lowered..
Crippler
05-03-13, 02:35 PM
Omg . That's sick ! I would love if you could PM me the install cost and details ! I've been looking to put my car on bags as well ..
gmax111
05-03-13, 02:48 PM
I'm not sure what it would cost.. I did everything myself so I know it's done right and I'm sort of restricted from talking about the cost of parts.. Im assuming a shop would charge around 5-6k for similar setup.. Sorry I can't be much help..
Crippler
05-03-13, 03:21 PM
Can you send me a list of part numbers ? Or can you suggest a website to order from .
Could you post a short video of the airbags working ?
EVH5150
05-03-13, 03:59 PM
I am so jealous! I have always loved the slammed look and always wanted to do this. You did a beautiful job my friend, a million thumbs up!!!
Crippler
05-03-13, 04:12 PM
I contacted accuair in California and they just supplied me with all the info I need ! Total coast $3200 for the hole kit and the i- level ! 10 days to ship ... So cool
arw1510
05-03-13, 05:41 PM
Good luck getting your golf clubs in the trunk now though lol. I'm not into those sort of mods but it looks like it came out pretty good
gmax111
05-03-13, 05:48 PM
Yes, thats about right, but beware its not bolt-on. Parts need to be fabricated..
Can anyone advise about running 20x10" rims?
OMG
05-04-13, 11:00 AM
Can't help you too much but D3 has quite a few pics floating around of CTS's lowered and on 20x10's they fit snug and flush. I'd help you find the pics but on my cell at the moment.
soku
06-29-13, 02:19 AM
Couldn't you fit the compressor and all the components in the spare tire well? That way you could have more trunk space.
CTS4MATION
06-29-13, 11:08 PM
Im sure he could do that but his setup looks very clean so why not show it off. Im running 3 viair 480s and an 8 gallon tank with cylinders on another car. I did hide the 3 compressors when I did it about 10 years ago and one of these days when the car is out of storage and my garage is finished I will be moving them into the trunk or inside the car. They produce ALOT of heat when running and with a 100% duty cycle compressor you can play and play with the switches, thus making heat that is trapped under compressed wood/cardboard. You are also limited on how you can mount them......short of making brackets to hold them in place. I actually mounted mine upside down on a hindged "trapdoor" for ease of access.
gmax111
09-12-14, 02:36 PM
Just thought about updating this thread with pictures from ~April 14'.
Ended up going with 20x9(Front) and 20x10(Rear) staggered set from XO Wheels. The offset if I recall correctly is +35(front) and +47(rear). The wheels had to be custom made as finding a rear pair with this high offset to fit the sedan is nearly impossible. Took me a long time to find a company willing to help me make a set to fit and completely tuck a 10 inch wide wheel under the rear wheel wells.
The paint in the pictures is a custom color/pearl plastidip and I have since peeled a resprayed the car with a flat clear plastidip over the original metallic silver. I daily this car and have never had any problems. The plastidip provides a protective coating to prevent minor rock chips in the paint.
http://imagizer.imageshack.us/v2/xq90/537/eFTa2D.jpg
http://imagizer.imageshack.us/v2/xq90/909/rjVzOA.jpg
http://imagizer.imageshack.us/v2/xq90/633/QVekoV.jpg
http://imagizer.imageshack.us/v2/xq90/902/gJ5wqs.jpg
Thanks to Kory Richoz for these amazing pictures.
is250sp
09-12-14, 04:58 PM
that looks exactly like my wheels http://www.stancewheels.com/wheels/stance-vip/sc5ive-matte-black-machined
brohd11
09-13-14, 02:43 AM
Sick dip man! Throw up some pics of the flat on silver, I was wondering what that would look like. Seen a Jag over on dip your car forums that looked sweet with clear over silver.
HurstGN
09-16-14, 12:24 PM
Is the plate making a statement towards something?
gmax111
09-17-14, 01:18 PM
Yeah Stance wouldn't make the wheels in the offset I needed to tuck the wheels. So I found another route. This was also when they had just released that style wheel so I don't know if it would be a different situation now. XO made them with no problems after they seen the car. :)
Thanks man, currently I'm waiting for a photo shoot to come through before I release new pics.
Nope just thought it was a cool plate to put on a CTS that lays out. And no one else took it.. haha
tinman
09-18-14, 11:18 AM
You've done a nice job.
