: Front A/C fan not blowing
sprink60
05-03-13, 12:45 AM
It operates while underway but when I stop it slows way down...what gizmo is acting up to cause this to happen?
wesyder
05-03-13, 01:02 AM
If its the blower motor acting up, possibly the blower motor resistor
the cadillac man
05-03-13, 01:24 AM
Either the blower motor or blower motor control module
sprink60
05-04-13, 12:58 AM
Thanks guys...seems like this afternoon it started working as it should...but I can't explain why. FYI...some times while sitting at a stop I hear a strange tapping from behind the dash on the passenger side...any thoughts on this one?
the cadillac man
05-04-13, 03:08 AM
The tapping is the actitutior traveling(or dithering) but if the blower motor isn't working it can only one of two things bad blower or bad blower control module(both are easy to replace)
To rid the traveling pull the hvac fuse in the under hood box for a couple mins then put it back in turn the key to run for a couple mins then back off and start the truck the hvac system should do a relearn process(mine did this and that is how I fixed it)
sprink60
05-04-13, 02:36 PM
I will try this. Mine is also doing the "fan/blower running after shut down" dealeo. Have you replaced your blower resistor/module? Is this a common part?
the cadillac man
05-04-13, 02:50 PM
If you blower is running with the key off then its the blower control module
sprink60
05-04-13, 03:04 PM
Is it this part?
https://acdelcooutlet.com/index.php/15-80567.html
the cadillac man
05-04-13, 04:32 PM
Is it this part?
It looks like its the right part
sprink60
05-11-13, 09:50 AM
OK..it was the resistor. GM has a kit that upgrades the resistor to a new style and it comes complete with a retro-fit pigtail and instructions....$60 out the the door at http://stores.ebay.com/Number-1-Gm-Parts. They are local for me so I just walked in a picked it up.
wesyder
05-11-13, 03:13 PM
Sweet
OCShaun
06-18-15, 02:59 PM
So I have a 2004 Escalade ESV and am having the same problem with the front fan not blowing but rear works fine. Are there two separate blower resisters for rear and front? I looked up the part for the blower resister and it looks so what simular but you can noticeably tell it's different.... If so, where would the "front blower resister" be located?
blaze190
06-18-15, 05:39 PM
Your blower motor control module should be located by the fan and kinda behind and below glove compartment. You will most likely have to remove the cover panel under glove compartment to get to the blower and blower control module
stanterra
06-23-16, 09:31 PM
I have the same exact problem and have replaced the resistor and the motor and still nothing....What else could it be?
the cadillac man
06-26-16, 12:38 AM
likely the havoc control module is bad.
