View Full Version : Rear Access Open Message
af908
05-02-13, 03:55 PM
Hi guys, I'm seeing a "rear access open message" on my 03 escalade, even though the latch and the glass are tightly closed. I just bought a multimeter, could someone tell me how to use it to verify which sensor of the three (one on glass latch, two on trunk latch) is bad?
Jophusp
05-02-13, 04:08 PM
Mine does the same thing from time to time, if I do not shut it hard enough. Seems to be the main trunk latch though, since it only does it after I open the whole door, vs just the glass. You might be able to tell that way. Sorry, never used a multimeter.
the cadillac man
05-02-13, 04:34 PM
I have this message pop ever so often and I normally take wd-40 to all three catches and it goes away
af908
05-02-13, 04:51 PM
Yeah i tried that, didnt work for me...
the cadillac man
05-02-13, 06:11 PM
Then the inside trim panel will need to be removed to gain access to the latches
af908
05-03-13, 09:40 AM
Yeah, the two door latches are easily accessible just have to remove the torx screws. The glass latch i would have to remove the trim..... Does the trim just pull off? I dont want to break anything.
Does anyone know how to diagnose that it is indeed the door sensors versus needing a replacement BCM? Ive heard there is a way to test if it is an open or closed circuit but im not sure how exactly to go about that..
the cadillac man
05-03-13, 11:15 AM
If you have a multi meter that checks the ohms rating you can use that
I am pretty the trim panel just pops off(I can check my service manual to be sure)
af908
05-03-13, 02:40 PM
Thanks, but how would i go about checking the ohm rating? Do i connect the multimeter with the trunk sensors plugged in, or unplugged? If they are plugged in i would image i would have to strip some of the rubber off right? Also what should i be looking for in terms of an ohm rating? Sorry i'm really new with multimeters...
the cadillac man
05-03-13, 04:32 PM
Check the sensors with them unplugged from the trucks harness to prevent a false reading
As far as the reading anything but 1 (it may be different with different meters) is ok with the latches closed(take something and push them in before testing)
