: Engine Oil & Tranny Fluid
2013CTSV
05-02-13, 10:23 AM
Hey guys,
Quick question, what do you guys/gals use in terms of fluids for your cars? I was reading around and people say change your oil and tranny/diff fluid after a few hundred miles of owning the car and it makes a nice different in how its revs drive & shifts. Can anyone attest to this? Also what do you run and recommend?
Thanks
cruiser68
05-02-13, 10:34 AM
No change in performance with better oils. Just more insurance.
I run amsoil in both engine and tranny along with the rear diff. I changed the engine the first time at about 1000 miles and the trans the first time at 10K. I use OLM for oil changes. Change the diff after every track weekend. Change the trans every 15-20K.
Enjoy your ride!
2013CTSV
05-02-13, 10:40 AM
Enjoy your ride!
thank cruiser, what weight do you run for your engine oil? Also is tranny fluid tranny fluid and diff fluid diff fluid? What I mean by that is are there different weights to those as well that I should be concerned with?
baabootoo
05-02-13, 11:55 AM
I just follow the owners manual and live by that. From what I read, Dexron VI is almost a synthetic trans fluid due to it's properties.
2013CTSV
05-02-13, 02:45 PM
Yea that is probably what I will end up doing but people experiment and report back a lot of findings so its nice to explore options ya know.
cruiser68
05-02-13, 10:05 PM
5w30 in the engine, 75/140 in the rear diff for track weekends 75/90 for no track work. I like the Amsoil light ATF fluid as it is full synthetic and I like the extra insurance for track days. Dexron VI is semi-synthetic.
2013CTSV
05-03-13, 11:39 PM
Thanks! Appreciate that.
JGeezer
05-13-13, 11:27 AM
I have to update my profile, I found a super clean 2004 that I'm just getting into!
Which Amsoil ATF do you like? The MTF "Synchromesh" or regular ATL? My 80K mile synchros aren't bad, but I can hear some bearing noise at times when there's any pressure on the stick.
I also have (surprise!) some light diff whining. Not going to be a track car, but would you try the 75/110 or always stick with the 75/90 for street use?
Thanks!
