: 08 3.6 engine noise
Graysuns157
04-26-13, 03:11 AM
I'm buying an STS. I was looking at this 08 3.6L with under 40k miles. The noise kind of sounded like a belt tensioner bearing or maybe the infamous timing chain issue. It was a little confusing because it sounded like it might be coming from the back of the block (about the area in the video). It does not sound like fuel injector tick to me. No codes. Any input would be greatly appreciated. Thanks guys.
http://www.youtube.com/watch?v=mNslTd-K15o
oldcaddybuyer
04-26-13, 09:48 AM
I recently took mine into the shop for the same issue. It is making an odd noise and it is not the fuel injector. They gave me a service bulletin and said the noise is normal. I plan to take it to another GM dealer and try again. No codes for me either but the noise is ridiculous.
Graysuns157
04-26-13, 04:10 PM
Thanks for the reply oldcaddy. Does your noise sound the same as the one in the video? Do you know what FSB it was the dealer gave you?
Cadillac Cust Svc
04-26-13, 07:26 PM
Hi oldcaddybuyer,
I understand the noise from your vehicle can be frustrating. Can you please private message me your contact information, VIN and the dealership name and location you took your vehicle to that gave you the service bulletin.
Sincerely,
Laura M.
Cadillac Customer Service
EChas3
04-26-13, 08:36 PM
Do a few searches. The V6 has a little part near the back that gets noisy; not spendy.
Good luck!
curtc
04-27-13, 01:15 AM
EVAP purge solenoid is a common failure on the 3.6. When it's bad it creates a loud ticking from the rear passenger side of the engine.
EChas3
04-27-13, 03:35 PM
That's what's tickling my memory. Thanks, Curt.
Graysuns157
04-27-13, 09:52 PM
Thanks guys. It is louder on cold start up. It is louder on the drivers side. The reason I wanted to pinpoint it was just to make sure it is nothing major. It seems to run fine. With the mileage so low there should not be much wrong with it. I just don't want to buy something that needs thousands worth of work right away. Maybe Ill just buy it, but that noise in the video still makes me nervous.
curtc
04-28-13, 01:32 AM
I wouldn't buy that car...Go look at another one, that doesn't sound normal.
oldcaddybuyer
04-28-13, 05:56 PM
Sorry it took me awhile to respond. Yes, my engine sounds exactly the same. It drives me nuts! No way that noise is normal. The video you posted is the first I've found that sounds the same. I tried several STS on the lot at the dealership and they don't make that cyclical ticking noise. The service department said it was normal and refuse to do anything further and cite:
#07-06-04-025H: Information on Clicking/Ticking Sound/Noise Heard During Cold Start - (Jul 27, 2012)
However, the engine makes that noise when its warm. I can drive two hours, stop, and it sounds the same. TICK TICK TICK :bsflag:
I used the service department at the dealer I normally do business with and they thoroughly pissed me off. Parked it with an identical year and mileage STS and it did not make that noise. The service department said both engines sounded the same. They claim not to hear the ticking I do and said I hear the fuel pump which is supposed to be loud.:anibs:I will take it to the Buick/GMC dealer next to see what they say.
Both 17 year old Fleetwoods are quieter than my STS. I miss the N* in the 03 Seville. It burned oil but at least it didn't sound like a frickin wind-up toy.
Graysuns157
04-29-13, 05:54 PM
Ill pass on this one. Thanks for all of the advice. I might just get a N*. I had the head bolt problem on my 98, but since that has been fixed I might just avoid the DI and go back to the N*. Good luck oldcaddy. I read that FSB and it seems to fit in some ways but not in others. In the video (the engine is warmed up) it is faster than 1 per second and it just does not sound like the aux fuel pump or injectors to me (but I could be wrong). Hopefully the next dealer takes car of you. You might want to have them look at the FSB and admit that the noise does not really match the description:
"The 3.6L SIDI engine (VIN V - RPO LLT) uses a direct injection fuel system that operates at very high fuel pressures. A direct injection fuel system produces a rapid clicking and ticking sound that can be heard from the engine compartment. The sound is more evident when outside around the vehicle or when the hood is open. The sound is more noticeable during idle and is more frequent during a cold start, but lessens once the engine is warm. The rapid ticking noise on cold start up is the fuel pump (located on the rear of the left cylinder head) building up high fuel pressure. When the engine warm-up is completed, the high pressure fuel pump will continue to tick at a lower rate of approximately one tick per second during idle. The clicking sound is the fuel injectors pulsing on and off under higher fuel pressures. These sounds are the results of a normal direct injection fuel system operating properly."
oldcaddybuyer
04-30-13, 02:02 PM
I took the STS in today for a second opinion. The service manager heard the ticking noise and agreed with me that it was not normal. Its scheduled to go back Monday for further investigation.
Graysuns - smart choice to pass on that ticker. Get a N*
Cadillac Cust Svc
05-04-13, 03:41 PM
Hope to hear a good report after your STS goes in on Monday, oldcaddybuyer! Enjoy your weekend and if you should need any assistance in the meantime, please don't hesitate to contact us on the forum.
Sarah G. (Assisting Laura)
Cadillac Customer Care
Swanka
05-05-13, 10:04 PM
My 05 sounded like that on start up when I purchased it (about a week and a 1/2 ago) and had a slight whine sound when driving in city. Turned out that the power steering pump was failing. The honest dealership agreed and replaced it (no charge) after owning for two days.. (BTW a Chevy dealer, not a Caddy one). Happy to report that the car is quiet as an empty room since.
oldcaddybuyer
05-06-13, 10:33 AM
I pulled in to the service department and went in to meet with the service manager. He and a technician walked out to the car with me. Started the engine, popped the hood, and technician says "that's normal" to which I had no response. He said the high pressure fuel pump is cam driven and that is the noise. I said alright then, got in my car, and drove home.
Cadillac Cust Svc
05-07-13, 12:25 AM
Good to hear from you oldcaddybuyer. Thanks for updating us on your dealership visit. If you have additional concerns please let us know.
Sincerely,
Laura M.
Hi Swanka,
Glad to hear about your report that your vehicle issue was resolved. Enjoy driving your vehicle around!
Sincerely,
Laura M.
oldcaddybuyer
05-07-13, 06:52 PM
Sincerely,
Laura M.
Additional concerns? I still have the original concern. Nothing was accomplished other than wasting my time. I have not been able to hear the noise my engine makes on any other 3.6 except for the one the OP linked. I still do not believe the noise to be 'normal' and find it ironic how in both cases the service manager said "oh yea I hear that noise...doesn't sound right" but the tech automatically said "yea that's normal" without checking anything.
I don't know which is worse. The fact that it ticks or the fact that it is considered normal for an engine to make such a noise in a Cadillac.
KRSTS
05-07-13, 07:38 PM
I have an 08 3.6 DI and mine does not make any unusual noises except you can hear the injectors when the hood is open, but they are not very loud - just kind of a soft ticking..
Clark52
05-08-13, 04:00 PM
Just bought the 08 STS myself,.. and have the SAME TAPPING NOISE. It does not go away under any circumstances. I have read all forums, gathered info. from just about everywhere concerning these engines (3.6 V6 DI) and continue to get the same answers you do;..." these sounds are normal for this particular engine ." Injectors a/o fuel pump noise. Seems as though with all the complaints about these engines, GM should,.. by now, have some factory fix, or retro solution, or something. After all, these are CADILLACS,.. not lawn mowers ! PLEASE, if anybody out there has found a true remedy, PLEASE POST.
EChas3
05-08-13, 08:34 PM
Via mechanics stethescope or the old hose trick, it ought to be possible to narrow down the source of this noise.
Good luck!
dkozloski
05-08-13, 10:12 PM
Just bought the 08 STS myself,.. and have the SAME TAPPING NOISE. It does not go away under any circumstances. I have read all forums, gathered info. from just about everywhere concerning these engines (3.6 V6 DI) and continue to get the same answers you do;..." these sounds are normal for this particular engine ." Injectors a/o fuel pump noise. Seems as though with all the complaints about these engines, GM should,.. by now, have some factory fix, or retro solution, or something. After all, these are CADILLACS,.. not lawn mowers ! PLEASE, if anybody out there has found a true remedy, PLEASE POST.Ear plugs or turn up the radio.
Cadillac Cust Svc
05-09-13, 01:03 PM
Hello oldcaddybuyer,
I apologize for your dealership visit. I do understand how that can be frustrating, especially when the manager states that the noise does not sound right. Have you thought about taking your vehicle to another local Cadillac dealership to have another opinion?
Sincerely,
Laura M.
