: I think im flooded
04-25-13, 06:02 PM
I have a 96 fleetwood. I tried to turn it over today an it tried but then sounded like it flooded out. It would keep doin it. I listened for tha fuel pump an altenator but they both came on. im wondering if its tha fuel pressure regulator or maybe tha spark plugs???? please help
04-25-13, 07:34 PM
Have you checked for spark? Fuel pressure?
04-26-13, 12:26 AM
Pull one of your spark plugs to see if it is wet. If it is then you should have a dry set handy and throw them in. It should fire right up. A weak coil can cause a weak spark and lend itself to a flood prone engine. Make sure your spark is strong and then proceed from there.
04-26-13, 02:26 PM
Don't these cars have a flood-clear strategy in the PCM? I thought if you cranked it with the pedal to the floor (like the old days of carbs) it would recognize you were trying to clear a flood and cut fuel back.
04-26-13, 05:04 PM
Yes, they do have a "clear flood" feature.
04-27-13, 04:10 PM
Something new I have never thought was possible nor there about the PCM of these masterpieces cars , thanks for your posts
