: Cags eliminator not working
Dhale
04-25-13, 07:23 AM
So I got a cags eliminator of eBay and it doesn't seem to be working. Anyone have this problem?
darkman
04-25-13, 07:48 AM
You may have installed on the wrong harness - there are two in the same vicinity.
Andringa
04-25-13, 09:56 AM
I forget, aren't the two harnesses on opposite sides of the trans?
Either way darkman is correct, I believe the other plug is for the Reverse lockout solenoid, so until you get it figured out, be careful going into 5th gear to make sure you don't accidentally going into Reverse.
Dhale
04-25-13, 10:16 PM
Oh I'll check that asap:banghead:
You know what maybe that's why my auto mirrors haven't been working. I assumed it was the plug( assumption is the mother of all f ups)
robojesus
04-28-13, 05:24 PM
If you want to check and see if you plugged it into the reverse lockout harness, simply start in reverse, pop it into neutral after getting to about 10 mph, and see if you can get it back into R.
Dhale
04-29-13, 07:46 AM
That's what it was ,I realized after you mentioned the reverse lock out that the curb assist stopped working around the same time. Thanks everyone
