: 546 stroker with tbi
04-25-13, 12:19 AM
will it supply enough fuel if i put a high pressure pump in tank
04-27-13, 12:14 AM
YES all day long.
04-30-13, 08:36 PM
What computer are you going to use to run it?
05-07-13, 06:26 PM
i am using the 7427 ecm i started it it sounds pretty good but i drove it and it shifted into overdrive at 40 so i had to reprogram the drac box and i need to finish my exhaust
05-08-13, 09:46 PM
YES all day long.
I would think that larger injectors will be needed. GM did, using larger units on the TBI 454 units.
05-09-13, 01:25 AM
i am using the 94 95 tbi with what i believe are 45 lb injectors with the higher 32 psi pump and i drove it today and it is running very lean
