View Full Version : Need a change In the Transmission
Gas_Drinking78caddy
01-10-05, 09:25 PM
Hello Caddy Fans
I'm looking into changeing my transmission in my 78 caddy. I changed my engine from 425 to a 472. I want to know if any other trans I can bolt up to this engine. I what to try a 5 speed trany it has 3 speeds now. I'm thinking if I can put a 5 speed with over drive It would help on gas mileage.
Any body Have any Ideas please let me know.
Thank you!
lovcads
01-10-05, 09:33 PM
You can install a Buick/Olds/Pontiac tranny (2004r) with fairly simple modifications. Preferably from a Grand National. I would make sure your rear end isn't any taller than 3.42-1. Otherwise it will be lugging a little bit.
Night Wolf
01-10-05, 10:42 PM
700R4 are also good choices if you want the overdrive...
personally I wouldn't give up the TH400 for either of them... the TH400 is a far better trans IMO.... I can live with 3 speeds...
the stock rear end in these cars is a 2.28 open...
I like that engine bay! any more pics?
lovcads
01-10-05, 11:44 PM
You could put in a 700 but you would need an adaptor plate for the bell housing, more of a pain in the a**. If that's got a 2.28-1 rear that's way too tall for an overdrive. A 2004r and a 3.42 or 3.73 gear set would be sweet.
davesdeville
01-10-05, 11:51 PM
NOT worth the effort and cost of swapping. You'd end up with a weaker tranny anyway unless you go with a 4L80 (which is a OD th400).
lux hauler
01-11-05, 02:19 AM
I'd love to do a 200-4R behind my 500 but the cost to get it
to hold up to the torque just isn't worth it.
Spyder
01-11-05, 05:02 AM
awesome underhood pic...you should post one of the entire car!
