: Plasti dip question
Chosenone
04-23-13, 08:02 PM
107113I would like to add some matte black accents on the hood of my V. I attached a really bad quick mock up of what I am talking about. Instead of using vinyl I was thinking of taping off hood and using plasti dip since when it drives it has a matte black finish. Since plastidip needs an edge to break clean when you remove the tape I am wondering if there is anyway to do this with out pulling up the tape and having the plastidip come with it. I would rather not exacto knife it and chance cutting the paint. Any ideas?
PS This is an old pic by the way, the lame pin stripe has since been removed.
TheDarkKnight
04-23-13, 10:25 PM
In order to pull tape with messing up the dip, you have to shoot the area you wish to cover with the dip, then wait 1-2 minutes not letting it dry, and then re shoot whole area again. Repeat this process 4-5 times with out letting area dry, and after last coat, pull tape immediately. This will give you clean lines
Smokin80
04-24-13, 02:13 AM
+1
There is also another way. Put down a few layers of tape.....Put the first line of tape at the final spot you want the edge to be at and then do 2 or 3 more layers of tape but move the line in about a 1/16 or 1/8th inch. Then do a coat of dip and pull one line of tape. Repeat until you get to your final edge.
Warm that can up above ambient temp too and that will help get the least texture possible. I look forward to seeing pics as i havent done a large surface with plasti dip yet...nothing bigger than wheels and grills anyway.
Cheers
Chosenone
04-24-13, 02:00 PM
I am confused lol?
Smokin80
04-24-13, 04:56 PM
I am confused lol?
About which part?
Either do all the coats while the dip is still wet or put down 3 or 4 layers of overlapping tape and pull one layer of tape after each coat. Then let the dip dry and do another coat and pull the next line of tape before that coat dries etc etc
Chosenone
04-24-13, 06:33 PM
Sorry I was confused on the multiple tape procudure. So step 1 is tape off multiple layers of tape and then spray the plastidip down. Then do I let it dry or leave it wet then step 2 is to remove the first outside tape and then spray another coat of plastidip down then remove the next tape then spray another coat down and then remove the final piece of tape. Sorry I am being dumb on this but I guess I cant visualize it. Seems to me that when you got to the inner most piece of tape it would be just like taping off with 1 piece of tape and removing it. I must be missing something here. What do you guys think would look better, plastidipping the stripes or using matte vinyl wrap and trying to cut them to match?
Smokin80
04-25-13, 01:43 AM
you pull each subsequent layer before it drys. Then you dont pull off the plasti dip with the tape. Then let that coat dry.....then next coat and pull the next tape wet.
Youtube it...lots of vids on plastidip.
BUT...i recommend doing vinyl. Easy to cut...google knifeless tape. Makes doing designs and stripes super easy and the finish is perfect.
Good Luck
