: Turn signal is crazy
04-23-13, 01:22 PM
The left turn signal in my SRX is acting like it needs the bulb replaced. I changed the bulb as well as the socket and I still have the problem. Anyone else have this happen? I had a red squirrel do some damage to the insulation under the hood and I fear that he messed up something else. I hope this is a common problem with a fix.
04-23-13, 01:24 PM
What exactly is the turn signal doing?
04-23-13, 05:04 PM
Flashes quickly like the bulb is going bad.
04-23-13, 05:24 PM
Is it the back?
04-24-13, 05:08 PM
Front or rear? Do they function properly even though it acts as if they do not?
06-10-13, 10:32 AM
Kind of late on the response, I forgot that I posted a questions about this. The quick flashing happens on both the front and the back. The front is where I changed the bulb and the socket.
06-10-13, 11:46 AM
Still having problem? If so, do bulbs work? Brake light(same as flasher)? If front bulb is out, whole side flashes rapidly. Does hazard flasher work, both sides, front and rear? That would show bulbs good. If so, flasher module is bad.
06-10-13, 08:26 PM
Looks like a bad flasher module. The hazard lights all flash correctly. Does anyone have a part number?
