: sqeaking from front suspension possibly lower control arm bushing?
04-22-13, 06:10 PM
I am noticing loud creaking and squeaking from front suspension at low speeds and while turning. I took my kw shock coil over's apart this weekend and couldn't pinpoint any movement so I buttoned it back up and still creaks at low speeds. I was looking through old tsb's and found this, has anybody done this disk install on their own or had the dealership perform it? Its a disc put between the washer and bushing to prevent metal on metal contact.
tsb 06-03-08-008B
part# 19150047
color pictures of install
I have read rumors that revshift or creative steel is/was looking at producing front control arm bushings. Anybody know if that was lower bushings and how close they might be on it?
05-07-13, 04:12 PM
I haven't had this problem. If you can't locate the source with a visual like the TSB you referenced, try lubing it up. I use Prothane Super Grease.
You also might want to check your PS fluid since you mentioned it happens during turning.
