: LS-9 Cam
04-22-13, 02:08 PM
I see some of the LS-3 crowd using the LS-9 cam in motors that are not S/C. Plus some local guys where I am at say they are a good swap and are fairly cheap new. Any advice or opinions. I have an '05 LS-6. I am just trying to get some info.
04-23-13, 08:16 AM
You will gain with the LS9 cam for it has similar lift but more duration, and later you can hit it with a blower and enjoy it even more, HOWEVER, if you want wow cam and a maggie go with the GT9 from LPE. Its sick and sounds like stock with a little more tone
04-24-13, 07:30 AM
Square port heads want a cam with less overlap.
04-27-13, 09:57 PM
I have a LS9 cam in my car with PRC .650 lift valve springs. My buddy has the same in his vette. Look up camminc5 on YouTube. He has kooks and Corsa.
04-28-13, 06:25 PM
I thought about putting the LS9 cam in my 408, but decided to just reuse my stock LS6 cam instead.
04-29-13, 03:50 PM
LS-9 has a nice little lope. Nothing radical, just enough to know it aint stock!
04-29-13, 04:03 PM
GM hotcam is better choice for cathedral port heads. It will create more dynamic compression and get you better power under the curve: 219/228@.50 .525/.525 lift 112 LSA
The LS-9 cam has a much wider LSA-- I think 122.5. Not a good choice for an NA LS-6 motor.
04-30-13, 03:14 AM
the 122 is for FI, the larger the LSA the more air is forced in the chamber and not out the exhaust..
The LS6 cam has a 116 so i see a benefit where they can add a SC later on and not have to change the cam...
04-30-13, 10:46 AM
Thats why I got the LS-9 Cam, hopefully a Maggie will be on next summer! :cool:
05-01-13, 03:49 AM
go for it
