: 98 Catera timing belt, camshafts and crankshaft seal replacement....completed
retho78
04-20-13, 09:57 PM
Okay folks,
I finally finished working on the car and posting some pictures here. The car is running good and no issues.
Gates TCK285P timing kit used here. It might different for 2000 and 2001 Cateras
http://i513.photobucket.com/albums/t334/rtt78/Catera%20Timing%20Belt%20kit/P1040763.jpg (http://s513.photobucket.com/user/rtt78/media/Catera%20Timing%20Belt%20kit/P1040763.jpg.html)
http://i513.photobucket.com/albums/t334/rtt78/Catera%20Timing%20Belt%20kit/P1040766.jpg (http://s513.photobucket.com/user/rtt78/media/Catera%20Timing%20Belt%20kit/P1040766.jpg.html)
The old water pump was leaking
http://i513.photobucket.com/albums/t334/rtt78/Catera%20Timing%20Belt%20kit/P1040767.jpg (http://s513.photobucket.com/user/rtt78/media/Catera%20Timing%20Belt%20kit/P1040767.jpg.html)
http://i513.photobucket.com/albums/t334/rtt78/Catera%20Timing%20Belt%20kit/P1040769.jpg (http://s513.photobucket.com/user/rtt78/media/Catera%20Timing%20Belt%20kit/P1040769.jpg.html)
http://i513.photobucket.com/albums/t334/rtt78/Catera%20Timing%20Belt%20kit/P1040773.jpg (http://s513.photobucket.com/user/rtt78/media/Catera%20Timing%20Belt%20kit/P1040773.jpg.html)
http://i513.photobucket.com/albums/t334/rtt78/Catera%20Timing%20Belt%20kit/P1040774.jpg (http://s513.photobucket.com/user/rtt78/media/Catera%20Timing%20Belt%20kit/P1040774.jpg.html)
http://i513.photobucket.com/albums/t334/rtt78/Catera%20Timing%20Belt%20kit/P1040776.jpg (http://s513.photobucket.com/user/rtt78/media/Catera%20Timing%20Belt%20kit/P1040776.jpg.html)
I just used a pvc pipe adapter to install the seals back to camshafts and crankshaft. It was the same diameter and worked perfectly.
http://i513.photobucket.com/albums/t334/rtt78/Catera%20Timing%20Belt%20kit/P1040778.jpg (http://s513.photobucket.com/user/rtt78/media/Catera%20Timing%20Belt%20kit/P1040778.jpg.html)
This is the cordless impact tool I used to remove the crankshaft bolt. It came out with no problems!
http://i513.photobucket.com/albums/t334/rtt78/Catera%20Timing%20Belt%20kit/P1040782.jpg (http://s513.photobucket.com/user/rtt78/media/Catera%20Timing%20Belt%20kit/P1040782.jpg.html)
The old crankshaft seal was stuck in there really good so had to try really hard to get it out so you can see markings / scratches behind it.
http://i513.photobucket.com/albums/t334/rtt78/Catera%20Timing%20Belt%20kit/P1040785.jpg (http://s513.photobucket.com/user/rtt78/media/Catera%20Timing%20Belt%20kit/P1040785.jpg.html)
http://i513.photobucket.com/albums/t334/rtt78/Catera%20Timing%20Belt%20kit/P1040789.jpg (http://s513.photobucket.com/user/rtt78/media/Catera%20Timing%20Belt%20kit/P1040789.jpg.html)
http://i513.photobucket.com/albums/t334/rtt78/Catera%20Timing%20Belt%20kit/P1040790.jpg (http://s513.photobucket.com/user/rtt78/media/Catera%20Timing%20Belt%20kit/P1040790.jpg.html)
http://i513.photobucket.com/albums/t334/rtt78/Catera%20Timing%20Belt%20kit/P1040793.jpg (http://s513.photobucket.com/user/rtt78/media/Catera%20Timing%20Belt%20kit/P1040793.jpg.html)
Painted the harmonic balancer and the two pulleys.
http://i513.photobucket.com/albums/t334/rtt78/Catera%20Timing%20Belt%20kit/P1040797.jpg (http://s513.photobucket.com/user/rtt78/media/Catera%20Timing%20Belt%20kit/P1040797.jpg.html)
http://i513.photobucket.com/albums/t334/rtt78/Catera%20Timing%20Belt%20kit/P1040800.jpg (http://s513.photobucket.com/user/rtt78/media/Catera%20Timing%20Belt%20kit/P1040800.jpg.html)
retho78
04-22-13, 09:42 PM
Just a quick update - drove the car today and no leaks or issues. It's driving nice and smooth.
Grandmaster B
04-23-13, 02:49 PM
Cool. Did you leave the old seals on the lower plastic engine cover for good luck? ;)
retho78
04-23-13, 04:26 PM
The old seals were laying on top of the oil drain container I had under the oil pan while changing the oil and also to catch the brake cleaners I sprayed to clean the gunk behind the timing cover.
kaustein
04-23-13, 09:38 PM
Holy Crap! I'm impressed!
retho78
04-23-13, 11:09 PM
Thanks kaustein. I'm impressed too since this is the first time I did this and was little scared to start the car after putting everything back and it started right up and driving nice and smooth.
sirmqc
05-18-13, 11:13 PM
Retho787 - how did you hold the crank from turning while you hit it with the impact? The manual references bolting a special tool onto the crankshaft (using the balancer bolt holtes) that you use to hold the crank while breaking the bolt loose.
I'm trying to break mine loose, but its giving me some trouble. I'm using a 2 ft breaker bar... thinking I might have more luck with an impact.
Any thoughts or tips?
retho78
05-22-13, 10:06 PM
Sorry for the late reply.....were you able to loosen the bolt? The breaker bar won't work, unless you have something good to hold the crank from turning. I had the same problem and tried all kinds of tools and then ended up using the high impact cordless wrench and also used the crank / waterpump locking tool to hold it from turning much, basically just a
