: Cold air intake
mygpascaddy
04-19-13, 09:17 PM
I'm looking for a simple project to improve the performance on my 93 fwb. Has anyone put a cold air on and what were the noticeable changes?
selftaught
04-19-13, 11:07 PM
They never truly work, the stock box, was the only true solution for your engine. Cold Air intake is highly used in turbo applications. The K&N brand boasts they can improve gas mileage but its marketing gimmickry. Get a good quality Air filter and keep it stock.
carnut
04-20-13, 12:20 AM
I agree, bragging rights only.
csbuckn
04-20-13, 02:20 AM
Well I'm looking for a way to make a cheap cold air intake or a dual snorkel for the 500, any ideas? Personally, I believe in CAI's, colder air with less restriction means more top end air intake and a denser spark.
outsider
04-20-13, 09:32 AM
I've seen some people make their own cold air intakes using basic hardware store items like the flexible drier exhaust duct and PVC pipe with some clamps...then attached a basic k&n cone filter. not sure how well they worked but if you're looking to get creative there are ways.
MoistCabbage
04-20-13, 12:50 PM
"Denser spark"???
RippyPartsDept
04-20-13, 01:21 PM
spark density refers to how much energy is actually in the spark
http://thesis.library.caltech.edu/5868/
although i'm not sure how the air intake relates to that
jayoldschool
04-20-13, 02:23 PM
I'll disagree, and it's easy to prove. On the LT1 cars, one can use simple software to monitor engine parameters, including intake air temperature. Comparing the stock IAT to a car with a well designed cold air intake like the K&N (that uses a cold air box), or the SSRI (that pulls air from in FRONT of the rad), the IAT show a significant drop on the latter at both low speeds and cruise.
RippyPartsDept
04-20-13, 02:30 PM
:yeah:
but once you start talking about a northstar that all goes out the window and you will get reverse results
jayoldschool
04-20-13, 04:40 PM
Why would we want to talk about the Northstar? We like our engines pointing in the correct direction, pushing, not pulling. I also am a fan of head bolts that don't destroy engine blocks.
cadillac kevin
04-20-13, 04:54 PM
So there's no N* into brougham swap in your future? LOL
MoistCabbage
04-20-13, 04:59 PM
I think Chris's point was, the same mod will not have the same effect in all vehicles.
Without dyno results, or drag strip time slips, nobody can say weather or not a mod actually improves performance or not.
