: ABS - Traction Control
01-10-05, 10:09 AM
Having a issue with the ABS box located in front of the engine under the water pump. It seems that the cover for the box has been missing since I purchased the car. The ABS and Traction Control lights have been on the whole time also. Upon inspection the wiring harness for the abs had some water sitting on the connector causing the harness to corrode. Is there a common fix?
