: clogged heater core
04-17-13, 04:30 PM
I think my cooling system is blocked.I can hear water moving in dashboard.Inside not enough warm from fun.outside smell anti freezer after drive.Some one before me used seal tablet.
Engine not overheating.How I can check that?How to unblock system?Or heater core?
Car is STS 01'
04-17-13, 09:18 PM
You have air in the system and that is why you have no heat. Check the purge line for flow. It is what clears (purges) air from the system. If it has no flow, the clog is usually at the other end where it mounts to the hollow bolt at the crossover manifold. It's the bolt that needs to be unplugged.
