View Full Version : Memory seat problem
phigment
04-17-13, 10:23 AM
My drivers side memory seat will sometimes not move back when I turn the car off. Likewise if I press the "exit" button, the one between memory 1 and 2, it will not move back. I have found the p/n for the seat position sensor and thought that might be the problem? Also, something I've wondered since getting this car, is there a way to make the the seat move ALL the way back when I press the exit button? When its working properly of course. When it works, and I press the exit button, it will go back a little ways. If I press it again it will go back a little further. Is this the intended operation? I'm the only driver of this car so when I get this fixed I suppose I can just program seat position number 2 as my exit position. Anyone experience this?
Superjim
04-17-13, 12:21 PM
I turned off the automatic movement when turning the key off.
My EXIT button works just like yours... you have to push it a couple of times before it goes back far enough.
Like you... I am the only driver of my car.
I programmed the the Number 1 button for my exit position and the Number 2 button for my driving position.
I like it that way.
Tedk
04-19-13, 01:04 PM
I had a similar problem. Sometimes the seat would go back sometimes not. Also would not always go to the correct forward position. Posted here and people said check the battery and ground cable. Sandpapered the ground were it bolts to the car and replaced the battery. The memory seat has worked perfect ever since.
danog
04-19-13, 04:06 PM
#PIC3699D: Easy Exit Seat Operation - column driver memory personalization power seat steering telescope tilt - (Jul 7, 2009)
Subject:
Models:
2006- 2009 Buick Lucerne
2006- 2009 Cadillac DTS
This PI was superseded to include 2009 model year. Please discard PIC3699C.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern: (http://gsi.xw.gm.com/newsi/showDoc.do?docSyskey=2298073&from=sm#d90234e27)
Some customers may comment they are unable to program the Easy Exit Seat to their liking or that the seat stops short of the desired position.
Recommendation/Instructions: (http://gsi.xw.gm.com/newsi/showDoc.do?docSyskey=2298073&from=sm#d90234e37)
Ensure the customer is familiar with the intended operation. The Easy Exit Seat function is different than previous models customers may be familiar with. When the feature is initiated, on vehicles built prior to May 18, 2006, the Driver Seat will move down slightly and back 2 inches from its starting position. The power Tilt/Telescope Steering Column (If equipped) will move upwards 2 inches and inward slightly from its starting position. The seat horizontal travel was increased from 2 inches to 3.5 inches on vehicles built on or after May 18, 2006. The amount of seat and steering column travel cannot be personalized. The seat and steering column will move again by the same amount each time the exit button is pressed.
This is considered normal operation of the vehicle and no repairs should be performed.
On vehicles built prior to May 18th, 2006 the seat travel can be increased from 2 inches to 3.5 inches by Programming the Driver Position Module (DPM) with the most current calibration.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed
phigment
04-20-13, 08:20 AM
Thanks Danog
