View Full Version : Washer Fluid Low indicator on and reservoir is full
04-15-13, 10:31 PM
DIC shows washer fluid low but the reservoir is full. I ran a small amount out thinking I overfilled it. Didn't work either. I clear it on the DIC and it comes back after a short time.
Does this sound like just a bad sensor?
It's under warranty so I plan I have the dealer check it out.
Curious if anyone has had a similar issue. Annoying because it blocks other info in the DIC unless u continually reset it.
04-17-13, 07:37 AM
I had the same problem with my '08. They replaced the sensor after playing around with it for a while. No problems with it since.
