: Any 355mm rotors weights 2.5kg(5.3lbs)?
04-15-13, 10:12 AM
I've heard about that yesterday, but now still under testing.
It seems like powder-metallurgy mixed with ceramic and metal.
355mm rotor with bracket weight 5.34lb/2.425kg, could be lighter.
Designer told me the price by this dimension would be around 500-600USD, estimated.
How much weight about a CCB rotor at similar dimension?
04-22-13, 09:38 AM
Ah, you have a 370mm rotor, the V1s have the 355mm rotors.
You do shave weight going to a two piece design, as well as the added bonus of saving your hub bearings...
Brembo, Racing Brakes, and a couple other companies make rotors for your car already...
Research is your friend
