: Big electrical problems 90 Brougham
bikertrash3531
04-13-13, 11:55 PM
Went to take the car for inspection and registration and lost the following:
Turn signals (flashers, running, and brake lights work)
High beams (low beams work)
Back up lights
Fuel
Spark ( engine cranks over)
No burning smell or smoke was detected
The P.O's used a jumper wire in the fuse box to get the digital dash to work and also had a wire jammed into a fuse location with two 20amp in line fuses run to the HVAC fan motor. There are burn marks on several fuse locations on the fuse box. I'm thinking the whole fuse box needs replaced or maybe a ignition switch under the dash( if there is one)? If it is the fuse box, where can I find one? Parts stores don't have them. Rockauto doesn't have them either. Salvage yards are questionable. Anyone know where I can get a new one?
csbuckn
04-14-13, 01:52 AM
Seems more ignition or steering column related to me. Digital dash, spark, fuel, turn signals, HVAC and such all come on when you turn the ignition on. Does it run?
cadillac_al
04-14-13, 08:47 AM
You are going to need a fsm to test all those circuits and to find the relays. I'll bet a relay or fusible link may have failed but the trick is to find it. These are the kind of problems that I hate and I wish you luck.
bikertrash3531
04-14-13, 12:26 PM
Fsm? I just think its strange that all these thing quit at the same time. I mean, I parked the car to get my personal property tax statement and it was working and running fine. Got back into the car and it wouldn't fire. Before I left the house I double checked all the lights and they were fine. I'm pretty sure these things all failed simultaneously. I just think its weird that relatively unrelated systems failed all at one after running fine.
bikertrash3531
04-14-13, 02:02 PM
Never mind the FSM question. Factory Service Manual. I bought a Chiltons for 67-89 Cadillac's. I know its not the 90, but its as close as I can get. Especially with the wiring diagram. Even then the diagram is incomplete. However, I couldn't find anything in common with the wiring of the failed systems other than the fuse block. I guess I'll check wiring with a multi meter until something that makes sense.
The Ape Man
04-14-13, 03:26 PM
Change in the cigarette lighter?
bikertrash3531
04-14-13, 06:58 PM
^^^^ I wish it were that simple lol. There isn't very many of these cars around and I hate to think of what it would cost to have a shop fix all the rigged up crap in the electrical system. I called the little bro over to have a look. He was an avionics electrician in the Navy and his thoughts were "what the @#$&#@ kinda @#$&#/$ is this!" We tested all fuse slots for volts. The affected systems all showed 5 millivolts. The rest were 12 volts. Something has these systems shorting or something. My lovely wife found a website dealing with GM only parts, hopefully we can get the fuse box out and see if anything appears faulty and get a new one or a tested salavage part. If not we may research scrap prices. I don't know.
cadillac kevin
04-14-13, 07:06 PM
Don't scrap the car :( there's enough of them getting scrapped from people neglecting them and beating them into the ground.
bikertrash3531
04-14-13, 09:00 PM
Scrapping it will be the last thing we do. That comment was purely frustration. Apologies. I just got off the phone with an old family friend of ours that worked with GM for years. One thing he mentioned was the solenoid on the starter. It made no sense to me until he explained that if bad it could allow certain things to function and not others because the main ground runs to it unlike the Fords I'm accustomed to. In a way it sounds plausible but I have serious doubts. With the multimeter readings and the crap repairs I found in the fuse box, I'm still leaning towards the fuse box. I'm going to step away from it for a couple of days and see if in can get more info on retaining parts and diagnosis.
How many volts should I get in testing the ignition coil output? Right now we have about 11.5v from the connection on top of the coil. Does any one know what voltage I should have at the injector connections? Lastly, where can I find an FSM for this car? Internet searches haven't turned up anything.
Thanks for all the help so far guys!
cadillac kevin
04-14-13, 11:49 PM
This is what you want (and this is about the going rate for them). If you go to ebay, type in "factory service manual 1990 brougham", a few more of these will pop up (but this was the cheapest one shipped.)
http://item.mobileweb.ebay.com/viewitem?itemId=150972021346&index=1&nav=SEARCH&nid=12012341464
Sorry for it being an ebay mobile link (on my phone)
MoistCabbage
04-15-13, 09:23 AM
Non mobile link:
http://www.ebay.com/itm/1990-Cadillac-Brougham-Factory-Service-Repair-Manual-90-/150972021346?_trksid=p2045573.m2042&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3 D1%26asc%3D27%26meid%3D6979948147597831716%26pid%3 D100033%26prg%3D1011%26rk%3D1%26sd%3D150972021346% 26
bikertrash3531
04-15-13, 11:38 PM
Thanks for the link! I'm leary of eBay but in this case it may be my best option. Now worries about the mobile link as everything I do internet wise is on my phone as well.
cadillac kevin
04-16-13, 12:11 AM
I don't buy much on ebay either, but the FSM is one exception. Mine has been an invaluable resource for working on my car (and mine was about 25 shipped IIRC- which was far cheaper than the chilton/ haynes manual and includes a ton more info).
bikertrash3531
04-16-13, 08:52 PM
Called around and found another 90 in a JY close by. I asked them not to cut any wires and well......
http://i1229.photobucket.com/albums/ee466/vstar3531/20130416_191311-picsay_zpsd5fcc338.jpg
Before I settled on this one I had them do a search to find another car. Nothing within 200 miles of here. So they gave me this for nothing. I think I can make this work when the FSM arrives. Really I think the JY was smart in giving me this fuse box. The car it came from is loaded with parts I'm sure I can make good use of.
Time to get a soldering iron!
cadillac kevin
04-16-13, 09:31 PM
The wires they cut are part of the main harness IIRC. Unless you had them disassemble the whole car and pull out the entire run, that's the closest you're gonna get. When you do your fuse block swap (since the fuse positions and wire colors should be the same), do the wires one by one and you should be fine.
bikertrash3531
04-17-13, 01:31 AM
So I should pull the pins out of the box instead of soldering the wires with electrical shrink? Just worried about breaking some of the plastic that hold the pins in if I do it that way.
cadillac kevin
04-17-13, 08:01 AM
You won't be able to get them out and back in intact. They weren't meant to come out.
I was saying cut the wires from your fuse block one by one and hook them into the new fuse block.
bikertrash3531
04-17-13, 09:54 PM
Ah ok. Thanks. Providing the weather holds it looks like this will take place this weekend.
csbuckn
04-18-13, 12:52 AM
Big job not to be 100% its gonna work. I still think its ignition related. All the stuff thats not working on your car only works when the ignition is on(not sure about the high beams, I thought they were hot at all times). Do the radio, heat and windows work?
Without ignition, you would still have hazards, headlights, brake lights, horn, seats and mirrors.
bikertrash3531
05-03-13, 12:37 PM
Car is in the shop. They will check over everything before i go ripping into the wiring. My wife suggested this when she noticed the lack of enthusiasm I have for wiring. $100 to inspect and diagnose, IMO, isn't a bad deal. Lets see what happens.
csbuckn
05-03-13, 01:40 PM
$100 is great when you think about the possibilities of the car never recovering from a trip into the wiring harness. If you do replace the wiring harness/fuse box, you should remove the dash, it will make things much easier.
bikertrash3531
05-04-13, 01:18 AM
Thanks, I've already considered taking the dash out if I were to replace the fusebox. A couple more hours to take it out will save a lifetime on my back! Lol.
cadillac_al
05-05-13, 08:15 AM
I think if you studied the FSM in the jon for a few mornings several things would jump out at you that you could test. It takes me a very long time to decipher wiring diagrams but after a while it all starts to make sense. Most likely your problems are related to the back yard fixes done to your fuse box and only involves a couple circuits. In the worst case I think you should be successful in wiring in that new fuse box by cutting and soldering (Western Union splice) and shrink wrapping everything. Good luck.
