: radio problems! ...again.
ChurchSTSV
04-11-13, 12:26 AM
So I am retarded when it comes to using the search function. Anyway, so my radio totally stopped working. The screen is black and nothing works. Any ideas?
carter's_sts
04-11-13, 12:18 PM
My NAV unit did that once and I ejected the NAV DVD and it came back to life. Not saying that will work for you. I considered myself very lucky. I thought it was a goner.
ChurchSTSV
04-11-13, 12:28 PM
I have been reading some articles and tried ejecting anything. The NAV disc or the CDs don't budge. :(
STS LC3
04-11-13, 02:01 PM
Might try rebooting the system. Disconnect the negative battery cable for a few minutes, then reconnect it. Worth a try.
PGA2B
04-11-13, 02:54 PM
Church- I tried to call you last night but got no answer. Check your PM's.
ChurchSTSV
04-11-13, 03:15 PM
I got your PM, but i am at work and cannot use my cell. I was in Target last night and had 0 signal. Building must be made of lead or something.
ChurchSTSV
04-12-13, 08:04 PM
UPDATE: I smacked the dash directly above the radio today and it came on. IT'S ALIVE!!
anyway, should I still take it in? Is it worth the warranty deductible?
PGA2B
04-12-13, 09:53 PM
Depends on what your deductible is.
ChurchSTSV
04-12-13, 10:02 PM
$100
PGA2B
04-12-13, 11:26 PM
If you can take it anywhere you want go to Kachina and talk to Dan. He will have Mark work on it.
Cadillac Cust Svc
04-13-13, 07:58 PM
Hello ChurchSTSV,
I am happy you were able to get your radio to turn on again. I am sorry you have been experiencing this issue with your vehicle. I recommend taking it into a dealership to be checked out, because they can provide you with proper diagnosis on whether or not the issue needs to be fixed. I hope you have a great night!
Sincerely,
Laura M.
Cadillac Customer Service
ChurchSTSV
04-14-13, 06:13 PM
I would, but I've worked at dealership service before. If it works, it will just be an NPF. I'll wait until it goes inop again.
ChurchSTSV
02-17-14, 12:42 PM
Solution found! Got a call from the dealer letting me know there was some shorts in the radio harness. Haha! If I get more details from the tech I will share.
ChurchSTSV
02-27-14, 02:16 PM
Here is what they said:
C/S RADIO POWER IS INOP DOES NOT WORK, CHECK SYSTEM AND ADVISE..
CAUSE: WIRE BACKED OUT ON CONNECTOR FOR RADIO POWER
940 CEXT 2.00
PARTS: 0.00 LABOR: 212.96
70129 WIRE BACKED OUT ON CONNECTOR FOR RADIO POWER 2.00 NOTE CODES FOR RADIO CONNECTOR.
Once again, warranty.
fast_lane10
03-01-14, 11:14 PM
you seem to have lot of "shorts" in your car... first fuel gauge now radio. Did you consider looking at why its happening?
