: 08 dts
qseals
04-09-13, 06:52 PM
I recently purchased a 08 DTS from an insurance auction because I thought that was the only way I could afford one as nice as I have. I am rebuilding it to have it inspected and registered in Atlanta GA however I need to have the control module for the seat belts and air bags reset. Also need the clock spring that goes under the steering wheel...do you guys have any insight or direction I could go in to affordably have the control module reset. Thanks in advance guys
CadillacVogue
04-09-13, 07:23 PM
Best bet would probably be just to go to a GM service center.
danog
04-09-13, 08:24 PM
Repairs and Inspections Required After a Collision
Accident With or Without Air Bag Deployment – Component Inspections (http://www.cadillacforums.com/forums/#d6470e3)Caution: Proper operation of the SIR sensing system requires that any repairs to the vehicle structure return the vehicle structure to the original production configuration. Not properly repairing the vehicle structure could cause non-deployment in a collision or deployment for conditions less severe than intended.
After a collision, inspect the following components as indicated. If any damage is detected, replace the component. If damage to the mounting points or mounting hardware is detected, repair the component or replace the hardware as needed.
Steering column—Perform the steering column accident damage checking procedures. Refer to Steering Column Accident Damage Inspection (http://www.cadillacforums.com/forums/cellHandler.do?cellId=67697&refDoc=1465482&from=sm).
Instrument panel (I/P) knee bolsters and mounting points—Inspect the knee bolsters for bending, twisting, buckling, or any other type of damage.
I/P brackets, braces, etc.—Inspect for bending, twisting, buckling, or any other type of damage.
Seat belts—Perform the seat belt operational and functional checks. Refer to Seat Belt System Operational and Functional Checks (http://www.cadillacforums.com/forums/cellHandler.do?cellId=56657&refDoc=1465482&from=sm).
Seats and seat mounting points—Inspect for bending, twisting, buckling, or any other type of damage.
Passenger seat bottom with passenger presence system (PPS)—Check for any dtcs or problems that may cause the PPS not to function properly.
The roof and headliner mounting points.
Frontal Inflator Module Deployment (http://www.cadillacforums.com/forums/#d6470e66)After a collision involving air bag deployment, replace the following components.
Important: The front passenger seat is equipped with a PPS, which detects an occupant. If the requirements for disabling the I/P air bag are met then the PPS will communicate with the sensing and diagnostic module (SDM) to disable/turn OFF the I/P air bag, even in a accident. For more information on the PPS refer to Supplemental Inflatable Restraint System Description and Operation (http://www.cadillacforums.com/forums/cellHandler.do?cellId=62350&refDoc=1465482&from=sm).
Inflatable restraint I/P module, if deployed and after performing the necessary inspections listed above
Inflatable restraint steering wheel module
Inflatable restraint SDM
Inflatable restraint front end sensor, left/right
Inflatable restraint seat belt pretensioners
Perform additional inspections on the following components.
Steering wheel module coil and the coil wiring pigtail—Inspect for melting, scorching, or other damage due to excessive heat.
Mounting points or mounting hardware for the I/P, steering wheel module, SDM, and pretensioners—Inspect for any damage and repair or replace each component as needed.
Accident With Side Air Bag Deployment – Component Replacement and Inspections (http://www.cadillacforums.com/forums/#d6470e139)After a collision involving side air bag deployment, replace the following components.
Inflatable restraint side impact sensors (SIS), left/right, on the side of the impact
Inflatable restraint roof rail module, left/right, on the side of the impact
Mounting points or mounting hardware for the SIS—Inspect for any damage and repair or replace each component as needed.
Mounting points or mounting hardware for the roof rail module (left/right) on the side of impact—Inspect for any damage and repair or replace each component as needed.
Mounting points or mounting hardware for the SDM and seat belt pretensioners—Inspect for any damage and repair or replace each component as needed.
