: Hello - New proud owner 09 CTS
Jimmypooh
04-08-13, 01:31 PM
I finally found the CTS I've been looking for. 3.6 DI with manual trans. I finalized the sale a few days ago and am having it shipped in from out of state. I've included the build sheet that I found online using the VIN. Can anyone tell me if this will have the ambient lighting and 40 gig hard drive? When researching it seems that you don't always have to have TSQ for ambient lighting; It may come with other packages. Anything anyone can tell me would be helpful!
Thanks,
Jim
UAV INFOTAINMENT SYSTEM 005.1 INFOTAINMENT SYSTEM(UAV)
UE1 COMMUNICATION SYSTEM VEHICLE, G.P.S. 1 GPS 1 VEH COMM SYS(UE1)
UG1 OPENER GARAGE DOOR, UNIVERSAL UNIVERSAL GARAGE DR OPENER(UG1)
UJ6 INDICATOR,LOW TIRE PRESS LOW TIRE PRESSURE IND(UJ6)
UPF WIRELESS INTERFACE SHORT RANGE, VOICE REC VOICE REC WIRELESS INTERFACE(UPF)
UQS SPEAKER SYSTEM PREMIUM AUDIO BRANDED WITH SURROUND AMPLIFIER PREMIUM SPKR SYS W/SURROUND AMP(UQS)
U2K DIGITAL AUDIO SYSTEM S-BAND DIGITAL S-BAND AUDIO SYS(U2K)
U30 CLUSTER INST, TACH, CLOCK CLUSTER(U30)
VH9 ENVELOPE,OWNER INFORMATION MANUAL OWNER INFO MAN ENV(VH9)
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
VT7 OWNERS MANUAL ENGLISH LANGUAGE ENGLISH LANGUAGE OWNERS MANUAL(VT7)
V4W Unknown
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
XA7 WASHER NOZZLES, HEATED, WINDSHIELD HTD W/S NOZ(XA7)
Y43 SALES PACKAGE CADILLAC, PERFORMANCE PACKAGE 002 CADILLAC PERF PKG 002(Y43)
Y44 SALES PACKAGE CADILLAC, SEATING PACKAGE CADILLAC SEATING PKG(Y44)
ZAA TIRE,COMPACT SPARE COMPACT SPA TIRE(ZAA)
1SB PACKAGE-OPTION 02 (1SB)
1SZ PACKAGE OPTION- (1SZ)
19I INTERIOR TRIM COLOR (19I)
194 TRIM COMBINATION,BLACK LEATHER (194)
30U PRIMARY COLOR EXTERIOR, EDEN GREEN (30U)
6NZ COMPONENT FRT LH COMPUTER SEL SUSP (6NZ) SUSP(6NZ)
7NZ COMPONENT FRT RH COMPUTER SEL SUSP (7NZ) SUSP(7NZ)
8SU COMPONENT RR LH COMPUTER SEL SUSP (8SU) SUSP(8SU)
9SU COMPONENT RR RH COMPUTER SEL SUSP (9SU) SUSP(9SU)
AH8 ADJUSTER PASS ST POWER,8 WAY 8 WAY PWR ST ADJ(AH8)
AL0 SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR FRT PASS/CHILD PRESENCE DETECTOR INFL REST IND SENSOR(AL0)
AL2 CONTROL SEAT, POWER LUMBAR SEAT CTL,PWR LUMBAR(AL2)
AP9 NET,CONVENIENCE CONVENIENCE NET(AP9)
AQ9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING RECL FRT BKT ST,LUXURY(AQ9)
AT8 RESTRAINT PROVISIONS CHILD, RR SEAT, RR FACING RR SEAT RR FACING CHILD RESTRAINT PROVISIONS(AT8)
AY0 RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS, FRT SIDE, ROOF SIDE DRVR & PASS FRT SIDE & ROOF INFLATABLE RESTRAINT(AY0)
A45 MEMORY SEAT ADJUSTER, MIRROR, POWER, DRIVER & ENHANCED MEMORY PERSONALIZATION MEMORY MIR AND ST ADJ(A45)
CE4 WASHER,HEADLAMP,HIGH PRESSURE HDLP WA(CE4)
CJ2 HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT A/C FRT AUTO/AUX CONT(CJ2)
C3U ROOF SUN, GLASS, SLIDING, ELEC, TRANSPARENT GLASS FIXED PWR SUN ROOF(C3U)
DCP PROCESSING DIRECTIONS & CONNECTIONS SERVICE PACKAGE DIRECTIONS & CONNECTIONS SERVICE PKG(DCP)
DD8 MIRROR,INSIDE,REARVIEW,TILT,AUTOMATIC,LIGHT SENSITIVE I/S RR VIEW MIR,LIGHT SENSITIVE(DD8)
DR5 MIRROR,O/S LH + RH,REM CTL ELEC,DUAL MAN FLDG,HEATED,COLOR O/S ELEC REM MIRROR W/HTR(DR5)
E2C ORDER TO DELIVERY - EXPEDITE TO CUSTOMER
FE3 SUSPENSION SYSTEM,SPORT SPORT SUSP(FE3)
FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
GU6 AXLE,REAR,3.42 RATIO 3.42R(GU6)
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
IL4 TRIM INTERIOR DESIGN (L4) (IL4)
JJB PT DRESS SUBASSEMBLY NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY) PLANT OPERATION(JJB)
JJD I/P SUBASSEMBLY NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY) PLANT OPERATION(JJD)
JJL SUSPENSION FRONT NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY) PLANT OPERATION(JJL)
JJM SUSPENSION REAR NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY) PLANT OPERATION(JJM)
J55 BRAKE SYSTEM,HEAVY DUTY POWER HVY DUTY PWR BRK(J55)
KA1 HEATER - SEAT ST HTR(KA1)
KG9 GENERATOR,140 AMPERE 140 AMP(KG9)
LLT ENGINE GAS, 6 CYL, 3.6L, DI, V6, ALUM, 60 DEGREES, HO GM 3.6D(LLT)
MN6 TRANSMISSION,MANUAL 6-SPEED PROVISIONS(MERCHANDISING OPTION) 6-SPD M/TRANS PROVISIONS(MN6)
MV7 TRANSMISSION MAN 6 SPD, AISIN, 85MM, 4.1555 1ST, 0.7516 6TH O/D. 6-SPD M/TRANS(MV7)
NP5 STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
NT7 EMISSION SYSTEM FEDERAL, TIER 2 TIER 2 FED EMIS(NT7)
PDR CONTROL - SALES ITEM NO. 135
P63 WHEEL 18.0 X 8.0 ALUMINUM, POLISHED, UNFLANGED ALUM WHL(P63)
QUR Unknown
R9N CONTROL - SALES ITEM NO. 89
R9Z CONTROL - SALES ITEM NO.100
SLL SOLD ORDERS SOLD ORDER(SLL)
TT6 HEADLAMPS HIGH INTENSITY DISCHARGE HI INTENS DISCHARGE HDLP(TT6)
T96 LAMP,FRONT FOG FRT FOG LP(T96)
Ranger
04-08-13, 03:07 PM
:welcome:
77CDV
04-09-13, 10:29 PM
:welcome:
orconn
04-09-13, 10:35 PM
Welcome to the Forums!
arachnyd
10-15-13, 04:29 PM
Congrats!
I was looking for the same car for ages. I was about to settle for the non DI with the manual, but finally I found a car almost identical to yours. Mine didn't have the TSQ, but I do have the ambient lighting. I think you figured that out eventually ;)
Where did you get the build sheet?
