carguy16
01-08-05, 10:37 PM
If my coolant is low, would this not supply coolant to my heater core?? my over flow tank is ALWAYS at the half full tank, when cold or hot, but my light only comes on under heavy acceleration.
This probably means there is not enough pressure in the system, Im going to try to buy some coolant tommorow, and see what happens.
I had this theory, and someone else may have said it too, but under heavy acceleartion more coolant is TRYING to be pumped then whats there, which means if the surge tank emptys out, or where ever it goes, the low coolant light would probably come on until the RPM's drop, and the coolant flows slower and has more time to fill up.
Tommorow im going to take a closer look, it looks to me the only way to add coolant is through the recovery tank.
EDIT: After all, if the engine is hot, the surge tank should be FULL to the top, since its expanding due to heat! According to the manual the light comes on when your 3 liters low, so perhaps im border line? I also read in the manual that the fan will not turn on for heat unless the engine is hot enough for the heat to work, so you dont get blasted with cold air. If so, could this be a sensor bad, or no coolant going to my heater core? The fan DOES come on, but a damper closes and all I hear is the fan spinning around, no air coming out of any vents.
I've tried using DEFOG, it channels heat from the heater vents and the wind shield, but I still had no heat even with the thermostat at 90 degrees and a hot engine.:nono:
