: I found a set of used tires-will they fit?
V user
04-06-13, 01:44 AM
They are 255/35/zr18 90w will they fit my V1? They are only 500.00 for four with wheels
D3l7a3ch0
04-06-13, 02:57 AM
nope, not at all.
where can i find this sale, though :-D
just kidding, I'll bite: that sounds like the right size. are you saying they are already mounted on wheels, and it's all $500? (what wheels are they?)
they're lower profile than stock (I'm using 245/45/18), but they'll fit. meaning the total height of the wheel and tire as it's mounted, will be shorter. affects your speedometer reading, and torque, and top speed.
first number 255 is the width, second is the height of the sidewall (as a percentage of the width, I think), and last is... the diameter of the wheel it's supposed to fit on.
might be the same height sidewall, since the width is bigger than what I've got (245)
if i'm wrong, people will log in to slay me on the forums. just stay tuned.
thebigjimsho
04-06-13, 04:08 AM
Slayed.
Will they fit? Yes.
Will they look ridiculous? Yes.
That is a full 2 steps down in aspect ratio. My V with slicks that were 1 down looked noticeably smaller...
D3l7a3ch0
04-06-13, 04:29 AM
GUAHH!
(though I think you mean slain)
maybe it has a tread pattern he likes
AAIIIC
04-06-13, 09:18 AM
Will they physically fit on your car? Yes. Are they the right size? No, not even close.
http://www.rimsntires.com/specs.jsp
Not to mention the load rating is very low compared to stock.
Andringa
04-06-13, 11:47 AM
GUAHH!
Well... If they have a sweet tread pattern I say go for it!
Edit: after retracing I realized hat my sarcasm really didnt come through...that tire size is smaller than you should be using on the V.
D3l7a3ch0
04-06-13, 05:05 PM
will do this:
(in no particular order)
lower your car,
your shift points will arrive faster
speedometer reading will be inaccurate
lower your top speed
increase torque-iness
increase gap with top of wheel well
make ride harsher
brakes will feel grabbier (closer to outside of tire radius = more mechanical leverage)
car is lowered .825 inches
1/2 x (stock tire height->26.68in - 25.03in<-new tire height)
final gear ratios (speedo, speeds, torque-iness) will be affected by 6.18%
(stock tire circumference->83.77in - 78.59in<-new tire circumference) 83.77in = 6.18%
will feel like +24 ft/lbs of torque at motor
...readout will be higher than actual speed by 3mph every 50mph...
25mph = 23.5mph,
50mph = 47mph,
100mph = 94mph
correction: brake grabiness increases by 6.199% <-I'm not sure if the braking benefit is the percentage difference between stock and smaller radius, I have a feeling it might not be. but if it IS:
braking characteristics of the car goes from 1.06g -> 1.125g
which is equivalent to WRX-STI
and good for 10 to 12 feet better 100-0 stopping distance
repenttokyo
04-06-13, 07:53 PM
wow that's an amazingly complete answer post!
D3l7a3ch0
04-06-13, 08:14 PM
I'm glad you like it! I'm taking physics right now, and I love it~! (pre-engineering)
I would love to be proven wrong by an automotive engineer (any engineer, or physicist)... their advice tends to come with a mathematical explanation and I love that shit.
I don't think I want to work in the automotive industry, but I love me sum physics
at some point the motor loses the mechanical leverage benefit to the higher speed the drive train and shorter wheel/tire needs to rotate compared to the stock wheel/tire, and kinetic energy isn't linear; it's proportional to the square of its speed... (and it's the same wheel--it didn't lose 6% of mass to compensate for the 6% reduced circumference, and if it did, the whole rotating assembly(the system) would need to shrink proportionally (and it hasn't, it's the same wheel/disc/lugs/hub))
(similar mass/linear energy, but higher rotational energy of the smaller wheels.. to the order of +6% squared x 1/2...x 4 wheels... and now the motor has to push that~)
convert it all into newtons, and you see why the engine tops out after succumbing to air friction and rotating mass...
physics is ****ing beautiful. it's divine
according to the CIA world factbook, America is one of three remaining countries in the WORLD that hasn't adopted the metric/international standard (SI) system (https://www.cia.gov/library/publications/the-world-factbook/appendix/appendix-g.html). Burma, Liberia, and us. That should bother you. the Brits moved to SI after we rebelled, but we never made the change (Sir Isaac Newton lived 1642 – 1727, which is telling)...
I think we're gimping ourselves by using inches and pounds, rather than the measurement system of Physics (SI)... no doubt in my mind America is denying its school-going youth, the experience of discovering Physics (and the units they're accustomed to using, "clicking" together so beautifully).
International System of Units (http://en.wikipedia.org/wiki/International_System_of_Units)
http://upload.wikimedia.org/wikipedia/commons/thumb/c/c8/SI_base_unit.svg/300px-SI_base_unit.svg.png
I might've taken an interest in school as a teen and not run off into the military at 18, and then spent my 20s there. Not that I'd do anything differently if I had the choice, but at the time I had no idea Physics could explain the world around me better than any answers I found in the last decade.
the reason why not switch to SI includes the cost of road signs etc. and all the infrastructure that uses pounds and inches... but I think TX as a state can handle the cost locally, I think we should secede and switch to SI.
//the important thing isn't whether I'm right, it's that I'm open to being wrong and interested in knowing what's right.
V user
04-07-13, 12:02 AM
I am impressed!
Thanks
A friend has them off a Mercedes
D3l7a3ch0
04-07-13, 07:54 AM
I've got it.
assuming the wheel is 22 lbs and the weight is evenly distributed, the shorter height wheel and tire combo requires 3 additional horsepower per wheel at 60mph, and that's pretty close to 6%...
I'm going to bet that had my estimations been more accurate, it would more strongly support the 6% figure, and show the net hp to "feel like -24 hp at the motor"
since the wheels are about the same weight but shorter, they require more horsepower to turn at a given speed compared to stock height, due to the increase in radians per second (radians = how many times does the wheel roll the distance of its radius. at 62 mph or 100 km/h, it's 82 times a second for the stock wheel, and 87.5 times a second for the shorter wheel... and those figures are later squared, and that's where the seemingly slight 6% difference becomes significant ...the difference of 5.5 radians is 6.28% of 87.5 radians)
stock wheel has 5563 Joules @100km/h (3864 Joules kinetic + 1699 Joules rotational)
short wheel has 5805 Joules @100km/h (3864 Joules kinetic + 1941 Joules rotational)
this is an increase in 242 Joules, or 242 kg x meters squared x seconds squared @62 mph or 100 kmh
which is equal to 178 lb/ft, (trust me)
and 1 horsepower is 550 lb/ft per second, so
550 foot pounds / 178 foot pounds = 3.08 hp. per wheel. required @62 mph or 100 kmh
so. it will feel like +24 ft/lbs of torque, and a loss of 24 hp at the motor.
stock top speed of 163 mph is reduced to 153 mph.
because the shorter wheel/tire combo needs to spin faster,
and the energy required to do that compared to stock is increased by 1/2 of +6% ...squared.
...yes if you note the time of the post it's 4:30 AM... this wheel problem has been killing me all day (it took me all day because rotational energy is next week's chapter or the week after that, and new concepts are accompanied by a 3-hour practical lab). Lucky for me, all I have going on this weekend is studying for an algebra exam Monday and a Physics exam Tuesday.
//tbjs, I'm going to bet you know what your "top-out" speed on your slicks is, compared to your stock tires, and that it's 3-4% lower with those 40 series slicks... possibly 5% since the rubber is heavier. (am I right :D)
Heavybody
04-07-13, 09:07 AM
It's awesome to see someone who enjoys what they are doing! Glad you like physics... And are here to give us the math & science behind our car questions!!
It's also refreshing for someone to be open to the possibility of being wrong !!!
Great thread so far
robojesus
04-07-13, 11:33 AM
245/45 is 110.25mm sidewall height.
255/35 is 89.25mm sidewall height.
So yeah, they'll work. Your speedometer will be off, and you'll have wheel gap, but if you're in a pinch and need tires, I'd probably go ahead and check craigslist before I did anything, tbh. People sell solid used tires for 30-50 bucks each constantly.
RyRidesMotoX
04-07-13, 01:15 PM
Way too much math/physics in this thread... I just trust the ol butt dyno, my ass never lies. And gauges of course. I love me gauges to see what the car is doing.
D3l7a3ch0
04-07-13, 11:54 PM
math city
math math city
ten ten ten twenty is fitty
joshuajohn1981
04-08-13, 01:18 PM
Yolo!
Motown Cad
04-10-13, 09:27 PM
OMG D3l7a3ch0,
I'm crying at your responses. You made my day and I'm thrilled to see that there is hope for our country with young minds like yours. I'm a Program Manager and manage Engineers. It's quite gratifying work. They blow me away with their knowledge/work and roll their eyes at me when I say "wtf did you just say? English please. Then the engineer humor attacks begin and I only get 60% of it. When their done laughing at me I say "Yeah, yeah... But I'm still in charge and it's hard leading five 50lb heads around and you guys do know that PM's refer to you as "gimps". As in "bring out the gimp" from Pulp Fiction. Good clean fun.
Go Aerospace!
carlson_mn
04-10-13, 09:34 PM
Tires are too small for car like others have said. I'm going up in overall size from 26.6 to 27" to close the wheel well gap a small amount and 1st gear is spun far too easily as is, not that .4" will make much difference either way though. I am planning on 255/45 for my next tire size.
D3l7a3ch0
04-11-13, 08:08 PM
OMG D3l7a3ch0,
Go Aerospace!
you called me ...young! you sir have made my week
thank you very much Mr Motown Cad.
rand49er
04-11-13, 09:23 PM
you called me ...young! you sir have made my week ...I could make your month! :wisdom:
But, check me if I'm wrong, but going to these tires wouldn't necessarily reduce top speed all the way from 163 to 153 since the torque as applied at the tire-pavement interface would be greater with the smaller diameter tires.
D3, you are indeed a refreshing character on here.
thebigjimsho
04-12-13, 10:44 PM
character, sure...
D3l7a3ch0
04-13-13, 06:44 AM
thank you, sir~
I got the high score on the physics midterm; 90% before the curve. but I have mixed feelings about it. the ones I missed were some of the easiest questions on the exam, and I didn't pay them enough attention. but I'm ok with it because this class is consistent in reminding me I'm not as smart as I think I am.
...but I'm going to ace the final, I know it! lol
re: the top speed.. it's a small difference in circumference, and at low speed all you feel is the better mechanical leverage so they're just plain torque-ier. the problem is the energy of a moving object increases exponentially with its speed (rather than linear). in the case of a rolling object, it has forward motion energy and rotational energy... and at 150mph the tires are screaming:
45 series tires spin 32.8 times per second at 150mph
35 series tires spin 34.6 times per second at 150mph
those extra 1.8 revolutions when it's already spinning 32.8 times per second (and travelling at 150mph) costs 7.5 horsepower per wheel. it's the same idea as when you're doing 60 and the car won't speed up unless you give it more power--on top of the power you're already using to do 60. at 150mph the stock V doesn't have any more power to give to make the smaller wheels spin faster.
you're letting me talk about this because you know I enjoy it, aren't you.
Andringa
04-16-13, 10:15 AM
thank you, sir~
I'm sorry, we can't accept these answers if you don't show your work.
D3l7a3ch0
04-16-13, 01:38 PM
sunovabiiiiiiiii!!!!!
