View Full Version : Parking assist problem
jalexand61
04-05-13, 01:29 PM
My 08 DTS just started having a problem with the front parking sensors. They have started alarming when I am driving the car and nothing is in front of me. The beep alarm sounds and the dash
light flashes (all the lights flash). To stop it I have to turn the front park assist to off. However, the front parking assist comes back on each time the car is restarted. It does not happen all the
time, but enough to make me nuts. I took the car in to a dealer and they said that the cars computer is not recording any fault with the front sensors. Then they advised that it appears the bumper
cover has been repainted and showed me where some clear had "pooled" at the bottom of each sensor and said this could cause the faulty signal. Then they quoted me a small fortune to replace
the sensors. I have owner the car three years and it never did this before recently.
If the clear is causing the problem, which I question since it did not do it before, anyone know a safe way to remove the pooled clearcoat from the sensors without damaging them?
Thanks
Superjim
04-05-13, 03:12 PM
If it just started doing it after you have owned the car for three years... it is VERY unlikely that the clear is causing it.
Next time it happens... while it is flashing, push the OnStar button and they can read the code remotely...
Then you can tell the dealer what code it is.
If you do not have OnStar....If at all possible, try to take it to the dealer when the lights are flashing.
It sounds to me like the tech at the dealer did not know how to use the TECH ll properly.
stormnn
04-05-13, 05:31 PM
Check that the senors are all out proud with the bumper cover. Someone in a park lot may have touched your bumper & pushed one in a bit. Then they do strange things. Happened to me. With a long screw driver I was able to get down behind the grill & pop it back out.
Norm
jalexand61
04-05-13, 06:31 PM
They are all in their proper postions. I read on another thread about a software reprogram for this problem, but it stated that it only applied to 2009 forward. Actually, I had the system checked by the local chevy dealer (no Cadillac dealer locally) and maybe they didn't know how to properly check them? But they said that all the gm cars were the same system?
Superjim
04-05-13, 06:46 PM
Do you happen to have a Buick dealer close by??
The Buick Lucerne is a lot closer to the DTS than the Chevy's are.
jalexand61
04-05-13, 08:01 PM
Well, actually the Chevy dealer is also a Buick dealer.
danog
04-05-13, 08:23 PM
#PIC5171A: Front Parking Assist False Detections Or Parking Assist Turns Off - intermittent - (Oct 8, 2010)
Subject:
http://www.cadillacforums.com/images/999999995.gif
Models:
2006-2011 Cadillac DTS w/ RPO UFR
This PI was superseded to update model years and procedures. Please discard PIC5171.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern: (http://www.cadillacforums.com/forums/#d96335e24)A customer may comment the LEDs located in the front parking assist indicator will illuminate suggesting there is an object in front of the vehicle when there is not. In addition, it is very likely that the PARK ASSIST OFF message is displayed in the DIC on some occasions and the customer cannot turn the system back on. Review of the Park Assist History Data with the Tech 2 will indicate “Hitch/ Obj Attach” as the reason in some or all of the disable records. The cause may be front license plate.
Recommendation/Instructions: (http://www.cadillacforums.com/forums/#d96335e34)
Scan all modules for DTC. Record any DTC found and clear them.
Review the park assist disable history stored in the vehicle. If the disable reason shows “Hitch/ Obj Attach” continue to step 3
Inspect the front of the vehicle for any of the following conditions and repair any discrepancies found. If none are found continue to step 4.
Improperly installed or crooked sensor
Silicone isolator ring surrounding sensor may be missing, cut, and or twisted
The sensor may be scratched or paint chipped
Excessive paint thickness on sensor after sensor replacement
Aftermarket bumpers
Hitches
Aftermarket license plate bracket.
Improper license plate bracket mounting.
Bent license plate (even a small deflection can cause this).
License plate frame installed. Important: The vehicle may need to be driven to remove the "Park Assist Off" message in the DIC and to clear the Park Assist Disable 1 History.
Drive the vehicle and attempt to reproduce the customer concern. If the concern can be reproduced, isolate the cause further by removing the license plate and mounting bracket one at a time a driving the vehicle to see when the concern can no longer be reproduced.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
