: Need radar instillation info-Where are the DIY folks?
flycaster
04-03-13, 08:05 AM
Although I just got a new ATS, it doesn't mean that I have to pay for things I can myself, eh? I enjoy simple modding and need to install my V-1. The only thing holding me back is finding out where to place the wires and how to get to them. Some have run them along the windshield roof liner and down into the fuse box. OK, I can see it is easy to tuck the wires in the liner, but the fit between the A pillar and the dash seems to be too tight for wire tucking. If I'm wrong, let me know.
I would prefer to either get a Blendmount and mount the V-1 under the rear view mirror, or mount it on the driver's visor using the V-1 visor clip. In any event, I will need to tap into the overhead console or the rain-sensor assembly. And this is where I am stymied: 1-How do you open the console or rain-sensor? 2-Which color wire goes on and off with the ignition and which color wire is the ground?
Stevo Supremo
04-03-13, 10:39 AM
I'm actually going to be installing a dash camera when it arrives (lotta crazyass moronic drivers around here, almost been hit a few times)
I was looking at tucking wires as well and I See what you're saying, the headliner is an easy tuck but yeah, the pillars are extremely tight and I dont wanna pull the pillar off because it'll never go back the same.
The fuse box is on the drivers side. See page 10-36 in the owners manual. I'm gonna hook it into the heated steering wheel fuse (seeing as I dont have a heated steering wheel) I'm just trying to find out how to tuck the wires, I'll post any ideas I get :)
westcoastats
04-03-13, 01:21 PM
I installed my Valentine 1 and used a double tap mini fuse in the fuse box for power - ran the wire( which is a flat phone cord ) up and to the dedector just above the rear view mirror(left side ) I did remove the piller cover and it went back on no problems ( just be patiant and remove gentley ) looks great and works perfectley as far as range and view of the road
bungee91
04-03-13, 02:08 PM
I ran mine between the pillar and the dash, and although tight, it went in just fine (the cable is like a flat phone cord).
I have my radar detector just right of the instrument cluster, and the wiring is into the driver side fuse panel, tied to one of the accessory fuses.
It is nice also (mainly just for the wow factor) because the radar detector stays powered on until I open the door, or the R.A.P. (retained access power) time runs out.
I did notice while running it that there is a lot of room at the back of the dash/firewall for running wires though.
There seems to be a thick rubber seal that mounts between the back of the dash and the firewall that would allow you to snake wires down pretty easily.
I think I would have preferred to run it that way instead of jamming it between the pillar and the dash, however it still turned out well.
Take a look at the pics below, I had issues embedding them (I think it's DropBox's fault) so you'll have to click on each to see them.
I prefer the radar detector at this height (it's super easy to glance at), however sensitivity is harmed by not mounting it up higher.
My wiring into the fuse panel isn't the best, and not my best work, however it works reliably. The positive wire is wound around the leg of the fuse, and the ground has a ring terminal and tied into a bolt right near the fuse panel.
https://www.dropbox.com/s/6xlp7ifk2il3mbe/IMG_20130403_125100%20%28Medium%29.jpg
https://www.dropbox.com/s/1ihifutpuptn1rl/IMG_20130403_125113%20%28Medium%29.jpg
https://www.dropbox.com/s/pmc1cpnrpro9zk2/IMG_20130403_125123%20%28Medium%29.jpg
https://www.dropbox.com/s/phednnyoablx2ze/IMG_20130403_125129%20%28Medium%29.jpg
https://www.dropbox.com/s/d8sefj59s1cstpj/IMG_20130403_125213%20%28Medium%29.jpg
Stevo Supremo
04-03-13, 04:24 PM
thanks for the info, did the pillar just snap off? ( I see no screw covers) and wich fuse did you tap?
& thanks for the pics bungee :) I think I'll mount my camera up high though, you're supposed to right?
I'd get a Lidar detector if I could, but if you get caught with one in Ontario they'll rape you on the spot
flycaster
04-03-13, 05:07 PM
OK, Bungee, you've convinced me to take a second look at the liner/A-pillar type of install. Could please be a little more descriptive on just how you removed the pillar - what kind of tools used, where did you start the removal process, etc? Also, how did you put it back on - reverse process? And, what problems had you encountered while doing the removal/replacement? BTW, I should hear from Cadillac service on how to tap into the overhead console or rain-sensor Monday, if they consent to show me. In either case, I plan to have the V-1 wire either exiting the liner or overhead at the mid-point (where rear view mirror holder is) so that only a very short, unseen, wire will be run to the V-1 mounted on the driver's visor or with a Blendmount (V-1 would be placed under and abutting the bottom of the mirror...these two mounting are the cleanest if one is showing the whole unit.
Cisitalia
04-04-13, 02:17 PM
Check out this thread with some pix.
http://www.cadillacforums.com/forums/cadillac-ats-technical-discussion-forum/276698-hard-wire-radar-detector-anyone-do.html
flycaster
04-04-13, 02:30 PM
Thanks, Cisitalia, but the only thing the pics are good for is showing the fuse box wiring and hook-up. We need to find out how to get into the overhead wires and which ones are on/off with the ignition.
Cisitalia
04-04-13, 03:12 PM
No need to remove the a-pillar. Just plug into the fuse that was discussed in the thread, then push the cord thru the gap between the dash and a-pillar. Then push the cord between the a-pillar plastic and the windshield, then around the top of the windshield and head liner to a point close to the top console. Mount detector left of top center console. Don't bother finding the wires in the overhead console; it is to much of a hassel. It is so easy to go the fuse panel route. The gap between the dash and a-pillar is tight, but easily done when you try it. Just use a slim, preferably plastic tool to push the flat phone cord thru the gap. The rest is real easy since you have larger gaps. Trust me this is the way to go. I have installed many detectors in cars. This is a 15 minute job at most.
I took the time to look at bungee's pix. He did it the way I described, but I took mine to the top of the windshield. That is my preference for the following reasons: mounted higher is more effective for radar wave receipt, sitting on the dash is an eyesore and easily seen by others, mounted high left of top console allows you the best vantage point and operating the controls, it is out of the way and nobody can really see it from the outside.
flycaster
04-04-13, 03:43 PM
Agreed, best position is under the mirror or on the visor.
OK, I think I'll try it, but first some clarification. I'll be using the V-1 power cord that has the filter/fuse attached to it. As the fuse assembly is to big to push through anything, I will work from the fuse box upwards to the windshield, leaving the fuse assembly in box area. Also, the other end of the power cord has male connector that goes into the V-1. I would imaging that it should be removed before trying to go from under the dash to the A-pillar dashboard junction so that it wouldn't impede snaking the wire up to the dash?
I have removed the fuse box cover and have no idea where to push the power cord as I see no gaps anywhere (looking up from the fuse box). I need more direction on what to look for and just how to snake the wire up.
I've done a fair amount of mods on my BMWs (radar, factory alarm installs replaced the pillars, hotwired radar and iPods, installed BMW factory alarm system, etc), thus I have no problem if I have to go to the overheads. But, I am having trouble finding out how to get the wire up to the dash. I'm sure that I am just not seeing something.
Stevo Supremo
04-04-13, 04:44 PM
I would tap into under the mirror, but I dont have any of the fancy gadgets like auto dimming and such lol
I bookmarked that "hard wire radar detector" thread, thats exactly how I'm gonna do it
Cisitalia
04-04-13, 04:44 PM
Yes you must not be seeing the concept. First take the phone cord male part and hold it where you think you will mount the detector. Then use the cord to follow the path down to the fuse panel. Keep the length position and add a few inches to the length. No need to take the male connector part off. Keep in mind you are working back wards and just using the cord to follow the path to locate a distance to start fishing the cord from the fuse panel.
Now start to fish the flat cord (keeping in mind the length you measured) from fuse box to dash a-pillar gap and up the a-pillar, over top of windshield/head liner to the position where the detector is. You should have ample excess that can be pushed further into the headliner to take up the slack. I mount mine with the suction cups on the windshield up against the left portion of the top console. That way the sun visor can still be used, but only vertical. Pushing it further hits the detector. So just vertical is fine and I have no problems that way. Also, flipping the visor down restricts anyone (cops) from seeing flashing detector going off if you want to conceal it that way at appropriate times.
As you stated, just put the V1 fuse connector in the fuse box area, rap it in a protective cover and tape it inside if necessary. Now look very closely and you can see where you can route the flat phone cord up the lower a-pillar and up around the dash gap. Fish the wire between the dash and the black rubber door seal, than around the lower a-pillar. It is easily done; you are somehow missing that part of the install. I must say, it is easy and you will say "duh" yeah that is how to do it.
Good luck.
flycaster
04-04-13, 05:42 PM
[QUOTE=Cisitalia;3275129]Yes you must not be seeing the concept. First take the phone cord male part and hold it where you think you will mount the detector. Then use the cord to follow the path down to the fuse panel. Keep the length position and add a few inches to the length. No need to take the male connector part off. Keep in mind you are working back wards and just using the cord to follow the path to locate a distance to start fishing the cord from the fuse panel. No problem here
...Now look very closely and you can see where you can route the flat phone cord up the lower a-pillar and up around the dash gap. My first effort to find any openings to fish the wire failed...saw no openings. Perhaps, you could tell me how I should position myself to see the openings? I couldn't do this - lie on my back and look up from under the dash - because the car was in the garage and the door wasn't big enough. I essentially bent my head down as far under the dash as I could...this really didn't give me a great look-see upwards. . Fish the wire between the dash and the black rubber door seal, than around the lower a-pillar. Are you saying that the wire should be "tucked" (tuck=fish?) in between the dash and the lower A-pillar? I could do it, but it will take a lot of pressure to get the wire to the point where it wouldn't be seen.
If my questions are confusing, let me know and I'll take some pictures and point out the areas where I'm having trouble.
Cisitalia
04-04-13, 06:18 PM
I pulled my fuse cover and took some pix for you. From this angle push the flat wire thru the small crack between the dash and the black rubber door seal. Use a plastic tool like I mentioned before or a small screw driver to push the wire thru. It looks hard, but when you attempt it, it is not that difficult. That first area and the rest of the small portion between the dash and the a-pillar is the most challenging, but very easily done none the less. After that you are home free. No need to have awkward view. Just get on your knees outside the car or squat and do the work from the pictures vantage point. Look at the below pix:
http://i46.tinypic.com/2ppas04.jpg
http://i49.tinypic.com/rutaaa.jpg
http://i48.tinypic.com/es2nog.jpg
flycaster
04-04-13, 06:36 PM
Hey, thanks for the effort(s); which BTW now brings the solution. Yeah, Duh, it is simple to do. What through me was that the fittings looked to be so tight, I thought one could never tuck a wire between the dash and the pillar...guess you can. Funny thing, I just took pictures and was about to draw diagrams on them to show you where my problem was...Thanks again.
Cisitalia
04-04-13, 06:42 PM
Glad I could help a fellow ATS guy out. Once you start to push the wire in the narrow gap, the rubber and the dash material go into compression and you have enough space to slide the wire thru. Same goes the rest of the way around the a-pillar and the dash. I used my George Forman plastic spatula to push the flat wire into the crevices and cracks.
So did you actually get the wires tucked inside and not visible? I can't see mine at all, at least from the casual observer that is.
flycaster
04-05-13, 08:10 AM
Interestingly, when you posted your last series of pictures, I was just about to post my pictures describing where my problems were. And, then I had the old "ah ha" experience, and I think everything clicked in. However, as I really want to be sure that I am going to do this right, I am posting my pictures to double check.
As the text on the pictures may be too small to read, let me describe them. First picture shows the wire (red squiggly) coming up from the fuse box and being tucked into space between dash and lower A-pillar. Second picture shows wire continuing to be tucked between dash/A-pillar and then proceeding up the pillar.
106244
106245
Stevo Supremo
04-05-13, 09:04 AM
wow you guys are really helpful! (no that wasn't sarcasm) thanks for taking the time to upload pics!
flycaster
04-05-13, 11:47 AM
Hi Stevo. Glad to be helpful. Don't know how much you are into DIY, but pictures do tell the best DIY story and all DIY'ers should learn how to do it. BTW, one of my concerns was that Cadillac buyers, for the very most part, wouldn't be into DIY (for various reasons). However, old habits die hard (and I really don't have deep-pockets, just retirement pockets - LOL), and when I got my 325i (retirement present to myself), I screwed up my courage and started doing some DIYs rather than give the money to the dealership (or stealership as many BMW owners call it). So, if I feel that the instructions and help are there, and I think I can do it, then it is DIY for me.
Cisitalia
04-05-13, 11:58 AM
Yes, you did it correctly! Congratulations.
I come from a long line of DIY projects (cars, home, air planes etc.). So if something comes up that is needed, I will try to do it first. A large amount of the ATS owners are coming from German car brands and strong car enthusiasts, so they are inclined to do DIY projects.
So what is next for DIY projects?
Stevo Supremo
04-05-13, 12:42 PM
I'm HUGE into DIY!! this is my old cobalt SS, not much stock about it, and I did it all it won car of the month on my forum as well :)
its lowered, got sway bar beams, rebuilt engine, intake, full exhaust, tuned, full interior was re done with moulded carbon fiber, re did the headliner in black OEM material, different rear bumper, full car audio build etc etc etc
http://i938.photobucket.com/albums/ad229/stevoelsupremo/IMG_7671.jpg
I love building custom things for cars and working on them, and its neat to have a new car and learn it all over again lol
mikesul
04-05-13, 01:10 PM
Flycaster, thanks for the pics. They are truly worth 1000 words. :)
flycaster
04-05-13, 01:53 PM
Yes, you did it correctly! Congratulations. Thanks.
I come from a long line of DIY projects (cars, home, air planes etc.). So if something comes up that is needed, I will try to do it first. A large amount of the ATS owners are coming from German car brands and strong car enthusiasts, so they are inclined to do DIY projects. Good to know. I'm now feeling a little more comfortable and hopeful that my questions will get answered in a timely manner by folks that know what they are doing.
So what is next for DIY projects? Not sure. But I wanted to take off the yellow warning stickers on the sun visors, and posted on the Detailing forum. 76 views and, surprisingly, no reply. Of course, I first ran a search and got nothing specific to the ATS - which may not matter. Also, I posted the "soak it in alcohol" method http://forums.vwvortex.com/showthread.php?4791409-DIY-Removing-the-airbag-warning-stickers-from-your-sun-visors) which I used on my BMWs and think it is a better approach than the various "heating" methods that have also been used.(
Wait, maybe I do have a simple mod I'm thinking of. Not for everyone, but it sure made my BMWs look real cool. I loved the color of the accessory lighting in the BMWs (that reddish-orange), so I went about making all the reading and wheel-well lights that color. At first I searched about buying bulbs that color, but they didn't exist. Still wanting the color and not having the bulbs, I then took a red and an orange marking pen, removed the lens covering the bulbs, and colored the bulbs. Absolutely looks great, IMO. Hadn't done the wheel well in this picture, but I'm sure you get the idea and can see the difference. So, now I'm thinking of doing the same with the ATS, but haven't decided on the color. I have (my wife's main drive, though) a Glacial Blue with platinum seats and black accents.
106256
Stevo Supremo
04-05-13, 02:06 PM
lol the first thing I did to this car was smoke out those side orange markers and I replaced the reverse bulbs with super bright white LED bulbs
flycaster
04-05-13, 05:19 PM
Yeah, I'm not cray about the side markers, but they are a real safety thing, so I'll leave them as is. But would like to know what you meant by "smoke out." Looked at the Putco LED bulbs. Amazon has them for $34/pair with shipping included. I see that 10-32 gives a pic and instructions on how to do the bulb replacement. Although it looks straight forward, anything I should be aware of?
I might be interested in replacing the interior bulb with leds, also. Maybe a nice blue to match the color of the car? Then again, leds are very bright and it may be too much light???
Cisitalia
04-05-13, 05:53 PM
The first thing I did was to remove the yellow warning stickers on the sun visors. I did not see flycaster's post on that forum, since I don't go there. I am not sure what DIY project will be next. They usually just come up some how.
Stevo Supremo
04-05-13, 11:16 PM
eh, no other cars ive owned have ever had such obnoxious orange safty cones strapped to it like this one did. I just smoked them out (mixed clear coat and black paint together) then sprayed them for a nice smoked out look while still retaining gloss.
I got my LEDS for $15/pair from a shop near me, really makes the reverse light look crisp, I'm happy with it. The "install" is straight forward, crawl under the car, take the old bulbs out and pop the new ones in
flycaster
04-06-13, 01:23 PM
Although I do see how to hard wired the V-1 via the fuse box-A-pillar-overhead liner route, I think I will hold off a bit as my salesperson said that he would get one of the mechanics to show me how to remove the rain-sensor and/or the overhead console lids to get to a hot wire. I still prefer this route as the wiring will be neater.
However, I do have some concern just where to place the V-1. With the visor placement, the visor will have to be positioned in a horizontal position in order for the v-1 to be correctly aimed. This may be an uncomfortable viewing position as it will bring the visor/V-1 relatively close to my head. My other option is to get a Blendmount and mount the V-1 just under the rear view mirror. However, this may be problematic in that since my wife and I both drive the car, the mirror will always have to be shifted about...and that may entailhaving to reposition the V-1 every time one of us drive after the other has driven. Oh well, one thing at a time.
Cisitalia
04-06-13, 06:50 PM
In my opinion this is the best location. It is out of the way and very easy to operate in this location. I leave mine in permamently. I only take it out for extended periods of time while parked (airport etc.).
flycaster
04-11-13, 01:52 PM
Just completed my install of the V-1. Wound up running the wires from the fuse box (fuse 18,) tucking in around the dash/pillar, tucking within and up the pillar, tucking in and along the headliner, coming out by the right side of the driver's visor and attaching to the V-1 (mounted via its visor clip just to the right of the vanity mirror.) The V-1, as others have stated, goes on with the ignition on and off when the ignition is off and the door is opened.
The advantages of this mount are:
1. When visor is up against the roof, the V-1 is just about invisible. It can't be seen from the front or back of the car, but can be seen if someone looks in from the side.
2. When the visor is in the horizontal position (position for V-1 to detect properly), it is still difficult to see as it is fairly well recessed back from the windshield.
3. If sun glare is a problem, the visor can be moved into a vertical position, but not further.
4. The vanity mirror can be used.
Visor against roof in up position
106619
Visor in horizontal operating position
106620
Disadvantages
1. For some folks the V-1 may feel too close to their heads for comfort
Advantage/disadvantage vs Blendmount
1. Blendmount looks a little more professional
2. The V-1 is significantly more visible with the Blendmount
3. If two folks drive the car and have a Blendmount, there may be a problem with the V-1's position vis-a-vis the mirror. That is, adjusting the mirror may require re-positioning the V-1
