: Changing from synthetic to regular oil
werwer2012
04-01-13, 03:45 PM
I just bought a 1999 Cadillac Catera and I was told that it uses synthetic oil. Well it is time for an oil change and I was wondering if I can change and use regular oil, as it cost almost a $ 100 for an oil change with synthetic oil.
Thanks...
elvin315
04-01-13, 05:27 PM
No problem. Just use the proper temp range.
werwer2012
04-01-13, 06:46 PM
How do I find the proper temp. range.
kaustein
04-01-13, 10:12 PM
5-30W should work. But I'd save the money and go a normal oil change. Your will need the money. Trust me! You can change your own oil if you still live at home and have a garage.
retho78
04-02-13, 01:12 AM
10w30 or 5w30 will work. I just changed mine by myself and used full synthetic this time and paid only $35 (oil and filter).
MoistCabbage
04-02-13, 02:13 AM
Owners manual, along with everything else you need to know about what oil to use.
werwer2012
04-02-13, 01:19 PM
Thanks to evryone for there help.
jupiter57
04-02-13, 07:27 PM
Yeah, personally, I would stick to the synthetic.
Only 2 time in my life have I switched, once from synthetic to dino, an once from dyno to synthetic.
The switch from synthetic to dino, truck started "burning" oil (Well, it was going somewhere as it had no leaks). Switched back to Synth. & oil consumption stopped.
However, the time I switched from dino to synth., the truck started losing oil, so I switched back to dino. Truck used oil from then on!
Of course, I'm Old School (I'm older than dirt!), si I tend to try to stick with the same oil the previous owner used, it's always seemed to work quite well for me.
Oh, one more thing, if your Cat has more than100K miles, I would go with 10w30, but that's just my opinion.
Submariner409
04-02-13, 08:29 PM
Use whatever oil floats your boat, as long as it's in the recommended viscosity range for your engine. Conventional, "blend" (what proportions ?) or synthetic is perfectly fine and none of it will leak out of a bad seal any faster than any other.
retho78
04-02-13, 11:14 PM
I always used synthetic blend 10w30 but this time trying out the full synthetic. Also in the owners manual I believe it says to use 5w30 for winter and 10w30 for summer.....don't remember exactly though.
JohnJJO
04-03-13, 09:08 AM
i have 2000 sport, since i got it i been using only Castrol GTX high millage - non synthetic, in my manual synthetic not recommend to use, i even called to my local dealer and he told me the same thing, that's sounds weird due to fact that older models are running on synthetic and why would GM chained filter from spin-on to canister type on 2000-01 models, All Cateras have same engine !!!! WHY??? i personally not recommend to swap oils from synthetic to regular and back, why ? well think about fact that your engine was running regular oil for 13 years, same stuff all the time , same chemicals for 13 years and u throwing in to it some thing else..... To late to do swap like that. i got my car when it was 126k on it, that's to mush to do switch like that, my friend owns 2010 Honda Civic that's runs on regular, but he switch to synthetic. not a problem when u have like 30k on it, not 130k..... synthetic oils not create oil leak, it makes seals leak more if they already was leaking.
MoistCabbage
04-03-13, 09:21 AM
i personally not recommend to swap oils from synthetic to regular and back, why ? well think about fact that your engine was running regular oil for 13 years, same stuff all the time , same chemicals for 13 years and u throwing in to it some thing else.....An engine is an inanimate object, it does not "get used to" things. You can change back and forth m as often as you'd like, at any mileage.
it makes seals leak more if they already was leaking.100% imcorrect.
JohnJJO
04-03-13, 09:38 AM
Watch real true mechanic..... who works on cars every single day! PART 2 are main !!!
watch it and just think logically!
part1
http://www.youtube.com/watch?v=lshd7WR-a6I&list=UU_q-UNDJeEBSHqKzAP_8x_A&index=22
part2
http://www.youtube.com/watch?v=3zEBI1QndPo
MoistCabbage
04-03-13, 10:32 AM
Sorry, not watching a youtube video to learn anything about oil.
The only possible way synthetic oil could possibly worsen a leak, is if it's higher detergent level cleaned built up crud away from a leaking seal, but that is very unlikely, and it doesn't make the seal itself leak any more. If an engine running conventional oil for 150K miles, had the oil changed on schedule, there will be no such buildup, and switching to synthetic will have absolutely no effect on leaks.
werwer2012
04-06-13, 02:27 PM
WOW, what a lot to absorb. I don't have a owners manual for my 1999 Catera. Does anyone know if there is a difference between using 10W30 synthetic and 5w30 synthetic. Not sure which one to choose from.
MoistCabbage
04-06-13, 02:41 PM
The difference between the two is the viscosity when cold. 5W 30 acts as 5 weight, and 10W 30 acts as 10 weight. Both are 30 weight at normal engine operating temp.
Unless you're in a particularly cold climate, either will work just fine. Some Googling might get you the answer from the manual.
retho78
04-06-13, 02:41 PM
go with 10w30
Submariner409
04-06-13, 03:08 PM
Moist Cabbage, Let's get together. We can put on some neat coveralls with all sorts of beer, tire and oil patches sewn on, use Charlie's transmission shop up the road for atmosphere, get a pile of different oil filters and make a YouTube of "The World's Best Oil Filter". We'd be rich. (I promise not to talk about Pennzoil synthetic, you promise not to talk about Shell Rotella, and Charlie won't say a word about Texaco Havoline MaxBlend) I'll supply the official Edelbrock, AMSOIL, and Coors ballcaps.
Folks, oil wars are always fun - if you want some REAL antagonism, opinion, flaming, lies, truth, hearsay and witchcraft - - - get into the hundred or so links in www.bobistheoilguy.com (http://www.bobistheoilguy.com)
When all else fails, read the owner's manual.
MoistCabbage
04-06-13, 03:30 PM
Moist Cabbage, Let's get together. We can put on some neat coveralls with all sorts of beer, tire and oil patches sewn on, use Charlie's transmission shop up the road for atmosphere, get a pile of different oil filters and make a YouTube of "The World's Best Oil Filter".And to think some people wouldn't consider that a good day :nono:
:highfive:
jupiter57
04-06-13, 08:22 PM
go with 10w30
From my earlier post:
"Oh, one more thing, if your Cat has more than100K miles, I would go with 10w30, but that's just my opinion."
Trust me, you'll be glad you did.
werwer2012
05-03-13, 10:16 AM
My Cat has 65000 klms on it.
retho78
05-03-13, 03:23 PM
I would recommend 10w30.
MoistCabbage
05-04-13, 12:12 AM
Based on what?
The owners manual will state ambient temp ranges for when to use 5W-30 VS 10W-30. Mileage is NOT a factor.
