: The engine has developed a knock
carsaremytoys
03-30-13, 10:21 PM
A little back story, because I like to tell a story. Bought a season pass to the drag strip, opening day is today. Fire the beast up this afternoon and I hear a slight knock, most people wouldn't hear it. I blow it off. Get to the track and take a breather and gather my bearings because I'm still getting used to 600+hp, hopping on the freeway I gave it in 3rd gear and I got the "traction engaged" message! Not bragging, but more adrenaline rushes when I drive this car than the 150hp (02 suzuki gsxr 750) sport bike I used to know as the only thing to get my adrenaline going. Ten minutes pass and I get in line, I'm two cars to the tree sitting next to a building with my window down, I hear the knock echoing off said building. I ask the traffic director "Is that me" he replies, "yes". I ask how to leave and he tells me to pull out through an opening, and states "don't blow it up"
We first thought rocker, but it may also be a bearing in the charger. It's not a bad knock, but it got worse from the drive there (20 miles) so I know it is something.
I have yet to tear into an engine, so I don't know much about them. I still have 30+ lbs of oil pressure at idle, I don't think it's that big of a deal, but, like I said, I haven't torn into an engine and have no idea what I'm getting into.
I know my description isn't much to go by, here is a video I took earlier today (before I left for the track). You probably won't hear the knock (drivers side is where it sounds like it's coming from) but I'm trying to give as much info as I can.
http://www.youtube.com/watch?v=7k-eyBRWH2c
I plan to get another video when I take the stethoscope to it to hopefully find out where it's coming from. I don't want to fire it up if I don't have too.
What I know about the heads is:
Ported and polished by BES engines
Patriot Gold Dual springs and Ti retainers
Comp cams 7.450 pushrods with Yella Terra rockers
I will ask the previous owner if he can find out more about who did the work (the guy he bought it from had the work done).
For those who want to help me figure this out, but don't know the car:
http://www.cadillacforums.com/forums/2004-2007-cadillac-cts-v-general/284959-i-bought-one.html
izcain
03-31-13, 03:38 AM
Pull the covers and take a look at it.
When you bought the car I assumed you pulled the tune and made sure it was safe before boosting on it right?
robojesus
03-31-13, 05:35 PM
what's the worst that would happen if you took your belts off that supercharger for a minute? that doesn't exactly sound like rod knock, but that could be your phone. maybe a collapsed lifter? any misfiring?
carsaremytoys
04-01-13, 10:40 PM
I didn't pull the tune, I was assured numerous times by the seller that it is tuned for safety. I'm set up to have it towed to a speed shop tomorrow. I will most likely have them dyno tune it (after they fix it). I just had my neighbor have a listen and made a small video. The beginning of the video is of the drivers side of the engine and then moves to the passenger side. The noise sounds like it's coming from the drivers side.
http://www.youtube.com/watch?v=***0IYKQGMQ
izcain
04-02-13, 12:00 AM
link no worky
D3l7a3ch0
04-02-13, 04:35 AM
the frequency of it should tell you something--crank- vs cam-centric (not official terms; made up by me just now)
...or ignition-centric.
...the crank turns twice for every revolution of the cam. the pistons and rods are tied to the revolutions of the crank, and everything in the upper half (heads/valves) are tied to the revolutions of the cam.
and if it only happens during a spark/cylinder ignition, that's significant as well. you can isolate that by disconnecting plugs one at a time.
you can also get yourself a cheap listening tool, basically an aluminum rod that will allow you to localize the sound by touching it to different parts of the engine
to get the most accurate indicator of the revolutions of the crank, use a timing tool that flashes a light at every ignition of one of the cylinders. a flashing light is easier to interpret than trying to keep track of the markings on the harmonic balancer with the un-aided eye.
it's pretty easy to tell whether a sound is at the same frequency as the timing light, or twice as frequent (or another rate altogether/irregular)
also check for a smell in the exhaust. oil smells like burned oil, coolant smells like... burned cat urine-ish.
//I just had a listen, that's more of a rattle, sounds rather irregular. how does it change with increased RPMs? (sort of a two-person job, one person to man the camera/mic).
who pulls a tune? the man admitted he's never torn an engine apart. he's here for help. what would you do with a tune, izcain? do you know how to read one? do you know someone who does?
like you wouldn't jump on a V with that motor in it, as long as it sounded fine. I would, no doubt in my mind.
//...wait. is it for sale? (discount for the noise?) :-D I'm such a dick. I'm just teasing, I think it's gonna be OK--I was expecting worse--like, an obvious knock due to blow-by (gouges in the cylinder walls).
truth be told, I don't have any personal experience with valvetrain failures nor have I heard them first-hand, so I am not qualified to say it isn't a pushrod or broken spring, or anything else loose under the valve covers (especially not from here). I've had everything else go wrong with engines of mine, though.
I was at one time long ago, an ASE cert-holding Air Force mechanic.
//izcain is just mad that you have a super ****in' awesome car. I think he's one of those guys who can't just be -happy- for people who have nice things
//so far it's been robojesus and izcain to the rescue. God help you
where are you? Los Angeles area, by any chance? I have... nothing going on Fri-Sun (full-time student now. your mom goes to college!).
oh nevermind. you're way up there. damn... that's you? shit, man, um...
ok, to share exactly what I'm thinking, I am curious exactly how much driving you did on the motor before the sound started. I wonder this because there are things like Lucas oil products that will thicken the oil and hide sounds and symptoms temporarily, say, long enough to sell a car.
I hope that's not the case... that the sale was driven by an imminent problem.
maybe there's just a switch you missed in the cockpit, or you gotta jiggle the handle or something. (just don't jump through the phone at 'im! [especially not on account of what I just said about the Lucas oil])
//I like stories, and humor. I was also a medic, and know that telling and relating to stories is an indicator of a favorable prognosis. having a name like robojesus is not.
//k i'm done. I'm not always like this. it's only when I'm awake. sorry
carsaremytoys
04-02-13, 07:54 AM
I haven't revved it since the noise started, but it's consistent with idle. I drove it 600 plus miles home, the noise came only 50 or so miles after that. I don't believe the seller tried to screw me, he has numerous thousands into it to make it good in the few months he owned it. The oil was changed hundred or so miles before I Bought it with Mobil one. I was told to change the oil before taking it to a shop, I think I will do this. Any filters and weight recommendations? I'm not even sure how much or if The pan is still a stock ls 6 I'll get under it as soon as I have the chance.
D3l7a3ch0
04-02-13, 09:20 AM
man, I forgot about how loud the exhaust is.
assuming:
-your oil pressure is 30 idle/40ish above-idle,
-you have fluid in the cooling system, and the temps are fine...
-and you don't smell oil or coolant from the exhaust...
try to:
1: isolate the sound with the stethoscope,
2: do this rev test (and get a recording of it):
4k (midrange) and hold,
then 5.5k (high-ish range) and hold.
sounds are more telling as you raise the RPM. as the engine speeds up, the duration of all the actions in the motor are shortened... this causes some things to float, others to bang harder... the timing advances, and oil pressure rises... the balance of rotating parts can improve or worsen (temporarily, through the different RPMs).
depending on the issue, the sound could simply speed up with the motor(in "lockstep"--you'll be able to tell, and it would indicate something linked directly to the crank or cam, and 2:1 crank to cam rotational ratio is key in determining that), but it could also get louder, get softer, or go away (indicating something secondary to the crank or cam, such as lifters, pushrods, rocker arms, springs, valves)
so. a useful sound bite would be bumping the rpm a few times ("stoplight revs"), and holding it at 4k and then 5.5k-ish.
doing it while rolling and accelerating under load might produce different results, as well.
and then there's figuring out where it's coming from--high/low? front/back? left/right... also try unplugging the power to the coils one by one (isolate cylinder spark/ignition)
also try disconnecting and reconnecting the battery to see if doing a "soft" reset of the computer makes the sound go away. (for the MAF and the speed density tune you have, which I'm not familiar with, but it's worth a try to "turn back" an error counter that the computer might have decided it had enough of--though 600 miles is a little long, and if what you say is accurate, the sound has grown louder...)
If you could reduce the sound coming from the exhaust, -somehow- that would help with this endeavor. maybe extension pipes trailing out the back end of the car, and under the garage door... I don't have ideas for that one, other than something like an exhaust extractor (like they use in shops).
It could also be something -really- simple, like loose exhaust flange bolts, or the headers coming loose from the block. aftermarket headers tend to come loose, constantly. exhaust leaks can sound like knocks but they'll also have a "putt putt putt" quality to it. see real quick if the sound is more noticeable under the car, nearer the transmission.
I should invest in a code reader; I would like to hook one up for this. they're inexpensive and they make bluetooth enabled ones that remain plugged into your computer and will send real-time readouts to your smartphone.. sub-$100 range, if I recall correctly. Ebay, and I've seen auto parts stores carry them)
lastly: do you still have full power out of the motor (has there been a noticeable drop in power)
carsaremytoys
04-02-13, 10:13 AM
I've never felt full power, I was nice on the drive home because I wanted to make it home, and I haven't turned off the traction control yet. I've been near full throttle, but for a very short time
ApacheDriver
04-02-13, 10:31 AM
D3,
I applaud your efforts to help Matt. I can also understand why you would suggest Lucas oil being used to hide noise. I want to ensure you and Matt that this was not done. Actually, you can tell if Lucas was used by looking at the dipstick and even more so when changing the oil. I would not of spent over 5 grand on the car before selling it if I was trying to hide anything.
To me, it sounds like lifter tic. There are common reasons for this. Deposits in the oil, bad lifter, low oil, or bent push rod. Although the oil had about 1k miles on it when he took it, I suggested he change it out and maybe put a slightly heavier weight in it just to ensure any deposits were not the issue. From there, taking off the valve covers to see where it is coming from is next.
I just read your comment about a loose header. That is a possibility also that I did not take into account. A long time ago, I drove one of my dad's hot rod's. I down shifted at a high RPM so they exhaust would pop. One too many times and it back-fired pretty loud. A similar noise, as a lifter would make, came afterwards. It ended up being a blown header gasket.
rand49er
04-02-13, 11:04 AM
D3, you crack me up. :thumbsup:
Actually, I had a header leak that may have sounded like this, but mine was more subtle, and my hearing wouldn't allow me to hear it though EVERYBODY else said they could. Had new gaskets put on, buttoned up really nice, and now it's quiet. The sound in your video does sound like that kind of leak, only more pronounced than mine. Sure wouldn't want you to undertake that kind of effort (and expense) unless you were pretty certain that's it, though.
Question becomes how best to determine if it is a header leak. D3's "stethoscope" recommendation is probably the way to go. Even a portion of a doggone garden hose with one end at your ear and the other end moved around and positioned down near the exhaust ports might work. You just need to focus such a listening device at the location of the noise and get it to your ear to determine exactly where it's loudest then better problem identification can occur.
My $0.02.
sssnake
04-02-13, 11:45 AM
I know the stethoscope method is widely recommended but on a recent issue w an ls1 this proved to be ineffective for me. You could hear the tick everywhere. It turned out there was a bent pushrod, bad lifter, and damaged cam lobe. There really is no replacement for opening the engine and investigating.
The garden hose should help to find exhaust leaks but if you have an aluminum block the stethoscope may not help localize the issue. Pulling the valve covers and checking for a bent pushrod and loose or failing rocker is pretty easy. Going further will likely require pulling the heads.
D3l7a3ch0
04-02-13, 03:50 PM
:-D
I did not mean to offend! the thought crossed my mind "what if" the previous owner is on the forums, but I did not consider it would be an apache pilot (gimme a break! lol are you WO or O-type?)
umm funny story about Rucker... anyway.
I feel like I should have asked:
-does it have solid lifters, or rollers, or hydraulic rollers...?
-did you gain altitude between the sale location and your home, by any chance. I have never messed with timing on OBDII engines, but... what's that about advance--maybe you need more octane...... (what does the +1 advance mean/how was that accomplished, I wonder)
what octane does it use? was there an explanation for the 8:1 compression and low boost? just curious
there is a huge chance I am wrong about everything I say, but if I'm wrong, might as well be wrong strong
izcain
04-02-13, 05:29 PM
Not sure where I have ever come off on these forums like I am not happy for someone having a cool or nice car. Why would I be on an Enthusiasts forums talking with other members if that was the case?
D3 your on a role today not sure what your getting at or where you get your information LOL
Nice to be singled out though! Geesh I feel special lol
I meant no disrespect to the OP. Was just seeing where he was at with his problem. Obviously D3 has it covered for you though!
I am one of the ones that babied the car home and DID pull the tune as soon as I got home and looked at it (maggied V) and it was not a clean tune AT ALL. So yes I ask if he checked this. But I guess we always trust what people tell us.
D3l7a3ch0
04-02-13, 06:38 PM
the whole thing? I did not see that coming.
//the more I think about it, the more the MAF delete bugs me. Try... an octane booster additive, one of those $5 bottles from Wal Mart or a parts store. Couple bottles of it, even
Assuming everything is in the same working order as when you picked it up, the only things that changed are the car's location (altitude, temp, humidity) and the fuel (octane)...
robojesus
04-02-13, 07:56 PM
what is "so far it's been robojesus" and "god help you" supposed to mean? i don't think you have a clue who you're talking to kid. news flash my dude, i'm not someone who puts 8 inch kickers in the footrests of the rear seating area.
when you've built a few engines, and done work on your car other than changing fluids, you can talk to me like i'm retarded. you're no expert. i wouldn't trust your ass changing my oil.
izcain
04-02-13, 08:09 PM
Or work on them for a living not just because something broke in my backyard.
I am done though, I don't want to muddy up the OP's post.
D3l7a3ch0
04-02-13, 08:11 PM
HA! Success! Funny you mention the subs, this was 100% about your previous subs comment :-)
And I know exactly who I'm talking to! Youre robojesus!
WIN. Made my day
//I misspoke earlier. A timing light will flash with each revolution of the cam, not the crank.
C'mon guys, don't be like that--OP shouldn't suffer for my behavior--if you have something to suggest, say it!
robojesus
04-02-13, 08:28 PM
Alright, back to trying to help this dude fix his issue.
deltaecho said that the headers back off of the block. They DO NOT back out of the block... they can unbolt from the head due to engine vibrations. Spray carb cleaner around the headers where they meet the head. If there is bubbling, then you will know you have an exhaust leak, not a surefire way, but it's a viable way. This is best case scenario, but highly unlikely.
second, you need to pull the valve covers. unbolt your rocker arms and remove the entire pedestal. you can tap on each lifter with a pushrod LIGHTLY with a mallet or hammer, if it goes down pretty easily, you have a lifter that is collapsing and is reinflated over time. That being said, if it's collapsed bad enough, the pushrod will be noticeably deeper down than the other 15 pushrods.
third, drain your oil. check for abnormal metal shavings. take your filter out, slowly cut it and strain it through a paper towel into a basin... then again, closely examine for excess metal shavings.
When I spun my rod bearing(s), I was unable to maintain good oil pressure, and the car had very little power, especially up top. This is rod knock (http://www.youtube.com/watch?v=I5VfzcXwi_Y&list=UUnzNzReUYI_3-m_hKWzUc7g&index=6) in an LS6... I do not think this is what your car has.
Forward to 0:37 in this video (http://www.youtube.com/watch?v=U41tjD1DvU8). This is what my cars valve train sounds like all the time, due to a massive cam and noisy ass dual valve springs. With the higher open seat pressure of the springs, the valve snap back to closed a LOT harder than what you're used to hearing. A quick google search of "dual valvesprings noisy" brought this thread. (http://ls1tech.com/forums/generation-iii-internal-engine/751130-patriot-dual-valve-springs.html) In my estimation, I would not be surprised if you had:
1. Collapsed lifter.
2. Bent/Damaged Pushrod
3. Exhaust leak.
I do not think you have:
1. Spun rod bearing
2. Spun/damaged cam bearing.
3. Bad main bearing.
If you could get me a higher quality sound clip, I could make further guesses.
D3l7a3ch0
04-02-13, 08:47 PM
oh, yeah. right... headers bolt to the heads (you sure?)
umm... the troubleshooter in me would like to know the location of the noise in relation to cylinder, and which cylinder's ignition it coincides with. you could narrow it down to a single set of lifter, pushrod, rocker, spring, and valve (based on the four cycles of intake, compression, ignition, exhaust compared to which cylinder's ignition spark corresponds to the noise). ideally.
an example of a useful finding: "the noise happens when cylinder 4 fires, but it's right above cylinder 1"
that's if the noise occurred cleanly, but that rattle sounded fast, like once per cylinder.
I've rebuilt one or two engines a year since 2003, of my own but usually someone else's to lend a hand. I'm not familiar with our motors and I tackle issues as they happen.
I'm rusty.
robojesus
04-02-13, 08:48 PM
I'm rusty.
Please tell me you're not on a car forum suggesting that I'm incorrect in stating that headers connect to a cylinder head, rather than a block, all while insulting me?
http://www.gtoforum.com/attachments/f14/3850d1231359826-livernois-ported-243-heads-cam-l_23de5f4a91254cc79445bc18d93e2c62.jpg
see the pairs of valves here in a 243 casting head? INTAKE AND EXHAUST MAKE A PAIR.
See the fancy orange stuff covering the strange shaped holes? Those would be the exhaust exits.
Your easiest bet is popping a valve cover and taking a look around, not sure why you're suggesting he use octane booster LMFAO.
And pertaining to the "rusty" comment, I'm afraid you're just not as smart as you think you are. The LS1 based engines are EASY and basic as hell to figure out.
And why does the MAF delete both you? Have you never heard of a speed density tune?
OP, I glanced at another video of yours, and I need to know why the CEL is illuminated in this video:
http://www.youtube.com/watch?v=m9MBFy__V2M
and listen to this video:
http://www.youtube.com/watch?v=fJCjjhcaTEM it's a dodge with a header leak.
PISNUOFF
04-02-13, 08:58 PM
D3 - You were going strong with the frequency of the noise but lost all credibility with what seems like drunken babbling then suggesting an octane booster.
carsaremytoys - Check the headers for a leak then remove the valve covers and take a close look at everything. You can also run the motor at idle with them removed without oil squirting all over. It's also real easy to pull the rocker arms and pushrods so you can see the individual cam lobes.
D3l7a3ch0
04-03-13, 12:42 AM
naw, i mean if it's a rattle more than a solid once-per-cycle sound, I'm thinking it could just be an altitude difference the engine can't handle as well as if it still had the MAF. and no, i'm not familiar with a tune that doesn't use a MAF to (I dunno) accurately measure how much O2 is entering the engine....
this is not a normal motor we're talking about, and we have ignored the CEL.
Vegas is 300 miles from me, and it's an altitude change of 2200 feet. OP drove 600 miles from where he purchased it? OP if you dropped significant altitude, it's effectively increasing the compression in your cylinders. 8:1 and 5.5lbs sounds weird-low, I wonder if it's that way because it's compression-sensitive (OR SOMETHING)
or the 8:1 compression ratio is inaccurate and it's actually higher
robojesus, I was kidding, yes you're right... man i was just playin' about asking are you sure...
look i'm sorry, I more than got you back for the sub comment in that thread some weeks ago
wow, I got you good, I even made you pull a head to prove a point!
//I would quit the internet forever if it turns out to be an octane/altitude issue(and I'm right). i promise
carsaremytoys
04-03-13, 06:59 AM
Cel is on because it doesn't have a maf
PISNUOFF
04-03-13, 07:40 AM
If the MAF has been tuned out, the cel should be turned off in the programming also. It's very simple to do and doesn't make sense why the code would not be disabled. Have you read the fault codes with a scanner lately?
carsaremytoys
04-03-13, 08:29 AM
I haven't read the codes, I trusted the previous owner on this. He said there is a way to turn it off, I just haven't messed with the efi live yet.
izcain
04-03-13, 11:25 AM
Do you have the EFI live software?
seems odd to go thru all the trouble of tuning it without the MAF and then not doing the much more simple task of just switching the code to not report.
carsaremytoys
04-03-13, 01:11 PM
I have the software, I just need to find time, working a lot, which is good, because I may have a large bill with this lol
robojesus
04-03-13, 03:12 PM
WIN. Made my day
Exactly which previous subs post are you referring to " some of ago"? I think you have the wrong guy pal
I agree. That would be one of the first things done with a speed density tune imo. It was either overlooked, or the tuner isn't worth a shit and probably broke the motor with his neglectful tuning.
izcain
04-03-13, 06:38 PM
Can't reply to your pm carsaremytoys it says your inbox is full.
carsaremytoys
04-03-13, 08:32 PM
Now empty
ApacheDriver
04-03-13, 09:17 PM
Sorry haven't got back to this. been pretty busy. To answer a few comments. The MAF delete is because of the SD tune. The CEL was not on when I bought the car. I had the clutch replaced and when they hooked the battery back up, it was there. It was scanned and found out to be the MAF. I picked up the car and was told it need to be re-flashed with the tune to have it Permanently turned off. I do not have the knowledge to do that nor the balls to reflash it without thinking I would mess it up. The more I here it and think about it, I think the header gaskets may be leaking. Hope this helps. I will butt out of this conversation so others don't think I am trying to make excuses.
OP, give me a call if you need anything from me.
carsaremytoys
04-03-13, 10:14 PM
Are you saying the tune was deleted? The engine has been running without a tune!
ApacheDriver
04-03-13, 11:05 PM
No, I am saying the MAF needed to be turned off. The easiest way to do that was with the tune. You would definitely know if it didn't have the tune.
izcain
04-03-13, 11:23 PM
ApacheDriver,
Did you get the car tuned when you had it or were you running the tune from the previous owner? just curious.
D3l7a3ch0
04-04-13, 12:36 AM
what city was the car tuned in, and what city is the car in now? (I'm curious about the altitude difference)
...just, assuming the car is in the same running condition as when you picked it up, and no one's integrity is in question (nor is the integrity of the car).
easily ruled out if there was a gain in altitude, or no change. (no harm in asking, right? at the worst I'm wrong, and I'm ok with that).
robojesus: the subs comment, also the first time I knew of you (http://www.cadillacforums.com/forums/2004-2007-cadillac-cts-v-general/283050-its-getting-bad-i-cant-control-post3238603.html#post3238603). ...so I assumed robojesus was a troll account, and that you were game.
carsaremytoys
04-04-13, 07:00 AM
Picked the car up at the top of Ólabama it's now at The bottom of wisconsin
ApacheDriver
04-04-13, 09:42 AM
Tuned by previous owner. I did not change it. The tune is on the flash drive with the EFI live
robojesus
04-04-13, 10:13 AM
oh, no... this isn't a troll account. I just think you're an idiot.
D3l7a3ch0
04-04-13, 04:12 PM
welp, looks like it's not the altitude thing, and I don't have to quit the internet
this thread is a LOT of fun. I think we should all take a dance break. (http://hsmaker.com/harlemshake.asp?url=http://www.cadillacforums.com/forums/2004-2007-cadillac-cts-v-general/285952-engine-has-developed-knock.html)
yesthankyou robojesus, I am now aware that you are dead serial, and I will not disturb you henceforthwith. promise, girl scout's honor. (but in my defense, I don't think I'm a lot dumber than you thought that I think that I thought I was once.)
amen.
carsaremytoys
04-05-13, 08:44 PM
Efilive is on the CPU, just need to find time to play, put it in the air and have a good look around as well.
izcain
04-08-13, 10:03 PM
Get a chance to pull that cover yet?
carsaremytoys
04-09-13, 08:31 PM
No, I'm working so much and with this crappy weather, I think I'm gonna take it to the performance shop.
carsaremytoys
05-06-13, 11:26 PM
I got it to the shop Saturday, he pulled the valve cover today. Says it's a collapsed lifter and has to pull the head. Is it necessary to pull the head to replace the lifter?
izcain
05-06-13, 11:29 PM
Yes its the design of the LS motor. Glad he found something. Hopefully it didn't beat anything up!
carsaremytoys
05-09-13, 08:57 PM
She's back together, starts like it should, not hard and slow like it did. Lifter was collapsed 3/8 of an inch. Going to move the iat sensor to the manifold. And add a place to add coolant to the intercooler. I don't know how they got any in there, or if there is any in there, just a nipple to bleed if off... also have to find out why it's only making 5.5 lbs of Boost. Guy working on it tells me it should be making 10+ lbs judging by the pulley sizes. Maybe the 8:1 comp ratio? And then a dyno tune.. she'll be back at the track soon!
rand49er
05-09-13, 09:15 PM
I'm only making about 5.5 psi boost and even then that's only at about 6k RPM and above.
Car description says you're running an underdrive pulley. If that's on the crank, then that could be a reason you're not getting more boost.
What jackshaft pulley are you running?
carsaremytoys
05-09-13, 09:39 PM
I'm not sure about that pulley, the guy at the shop says the crank pulley is standard size, I don't know what size is considered under drive.
izcain
05-11-13, 12:45 PM
What s/c pulley is on it now?
robojesus
05-11-13, 01:37 PM
robojesus in post 3 said
collapsed lifter.
what do i win?
carsaremytoys
05-11-13, 02:28 PM
The guy doing the work said he is going to find out the pulley sizes. I'll know late Monday probably.
brngrhd
05-11-13, 05:53 PM
Carsaremytoys where in WI do you live? I just bought a v and live by Madison.
carsaremytoys
05-12-13, 05:57 PM
I'm in the Milwaukee area
brngrhd
05-13-13, 07:24 PM
Cool! Just saw your car on the LMT FB page
carsaremytoys
05-13-13, 08:37 PM
The guy at the shop didn't get into it yet, I'll let you guys know what he finds when he does.
carsaremytoys
05-15-13, 09:22 PM
He is working on it tonight!
carsaremytoys
05-16-13, 08:50 PM
IAT has been moved to the intake manifold and a tee has been added to the intercooler line (nearly a gallon of coolant was added, that can't be good). He told me that the Meth wasn't working. We looked a little closer and noticed that the control box was turned off. We turned it on and pushed the test button, the test/working light turned on. He asked me to place my hand by the injector while he pushed the test button to see if I could feel anything, I didn't. Is the test button supposed to spray when pressed? I understand that's all about how it was installed, but what is most common? The kit is Alky. I have the manual and it tells me that it is set to spray at 4lbs of boost. I have seen the test/working light come on when getting on it. I'm assuming it works fine, but am unsure. He tells me it was one of his employees that was working on it, and he wasn't around to ask.
carsaremytoys
05-21-13, 11:57 PM
Meth is working, a vacuum line fell off...
He took it for a spin and told me that it was only running 3lbs of boost and felt weak. That didn't sound right to me. He got back to me later and said that it had belt slip and it was because the guy that put the belt back on routed it wrong, I told him that he is the only one to touch it now lol. He states that it's back up to around 5lbs, but not quite "holy ****" I told him to make it holy **** lol. He is looking into the pulleys on the back of the motor.
brngrhd
06-02-13, 08:20 PM
bump how did things turn out here?
carsaremytoys
06-02-13, 08:57 PM
hopefully I will bring her home tomorrow!
brngrhd
06-02-13, 11:38 PM
What did they do with pulleys? What did it make for boost and power?
carsaremytoys
06-03-13, 08:47 PM
They gave up with the pulleys, couldn't find anything and blamed it on an outdated maggie 112. It made 460hp and 475tq at 5.5lbs.
It would be home now, but there are still a few issues. They refuse to hear the new noise the engine has developed and they are working on why the oil pressure gauge isn't working. He found that the harness wasn't plugged in and was ready to charge for for a new sensor and install. He says that it's now the harness...
brngrhd
06-03-13, 09:50 PM
Shouldn't a heads cam 383 make that power with out the blower? I'm hoping to make that with my stock motor and Maggie when I'm done.....
izcain
06-03-13, 11:01 PM
tune is off. I looked at it. I am sure it could use some retuning.
are you saying they are running this car without a working oil pressure gauge? I dont think I would be working with that shop anymore if they are.
brngrhd
06-03-13, 11:10 PM
Care to elaborate on what was wrong with the tune?
carsaremytoys
06-03-13, 11:17 PM
He re tuned it on the dyno. I'll pull it for you when I get the car back.
izcain
06-04-13, 12:00 AM
well that is good news!
it was off a bit when he started though wasn't it?
Did you ever figure out what pulley is on the snout of that s/c? 2.8, 2.7, 2.6 ect?
Another noise is developing? uh oh.....
carsaremytoys
06-04-13, 10:30 PM
It was off a bit, I can't remember what he said about which pulley is on it. I think the noise is an exhaust leak. They pulled the header, but didn't charge me for a gasket, I doubt they changed it, I'll have to ask him.
carsaremytoys
06-10-13, 07:55 PM
Brought it home today, you tell me if they fixed it:
http://www.youtube.com/watch?v=vkfdd6buKTI
Sounds a lot like it did before I took it to them:
I don't know what to do? He says that he warrantees his work, but I'm not gonna blow the engine for that. Ideas/thoughts?
izcain
06-10-13, 10:09 PM
Sounds like the valvetrain is still not healthy. I would take it right back to them.
carsaremytoys
06-10-13, 10:17 PM
I am taking it back, but I fear this is something that may go to court, he doesn't want to recognize that there is a noise?!? I don't know how to handle this one.
My thoughts are that I tell him to fix it, or he gives me my money back.
Has anyone dealt with something of this nature before? How did it play out?
izcain
06-10-13, 10:26 PM
if that is the case I would find someone else and just go for getting my money back. You dont want someone working on the car that is not competent enough to hear bad noises. I would find another shop. I bet one peak under those covers would show something not right. Could be just out of adjustment now. Never know until someone looks though.
Thats to bad that this is turning out this way for you though! Keep upbeat about it. You will get it fixed!
brngrhd
06-10-13, 10:40 PM
Sounds like left side of the motor..... I agree check under that cover and you will probably find something..... I'd take it back and talk to him if he still can't hear it then it is going to get ugly....
So it was making 5.5psi before then only 3psi after they got done? I hope to go they out all the lifters in not just one..... With the cam and everything you got going on are the push rods right? Are the springs ****ing up the lifters? Are the rockers still good. I would hope they would check all this stuff but.....
carsaremytoys
06-10-13, 11:40 PM
He told me one of his guys wrapped the charger belt wrong, it's pushing 5.5lbs again. But yeah, there are quite a few questions about this operation...
I told him to take a good look at everything and that I have no problem paying to make it right. He told me that it was just a bad lifter and there was no cause, just a faulty part.
izcain
06-11-13, 12:03 AM
Did you get the old part? Was the wheel all nicked up? Did they pull the engine all the way down or did they just replace the one lifter?
RyRidesMotoX
06-11-13, 04:36 AM
I'm sure they tossed it but that is a very valid question. Always have them show you what's wrong. A lifter that collapsed 3/8 of an inch??? (Per a previous post) Shit dude that seems like a lot to me. Granted I haven't really worked on hydraulic lifters before. (The old small block I built for a 55 pickup had solid lifters). Even though its a hydraulic lifter I can't really see it being collapsed 3/8 of an inch... I'm probably wrong though since I haven't had an LS apart ever. But that just seemed odd to me. Most cam lifts around .6xx +/- of an inch, does a hydraulic lifter really have that much movement in there (.375 of an inch)? I know they use oil as an incompressible fluid to actuate the push rod, rocker, valve etc but it seems like even drained they shouldn't have that much slack.
I dunno someone help me out here... Does that seem right or was the mechanic just blowing smoke to "fix" an issue that wasn't present? I completely agree it sounds like valve train, definitely top end of the motor. But I don't think the mechanic diagnosed it right, or maybe he did but there was more to it than just a lifter issue. What caused the lifter to fail? He failed to properly address that with you. Maybe it was just a faulty part but I would err on the side of looking deeper to make sure its not connected in some way to a bent push rod binding in the head or something causing a lifter to fail (like low oil pressure, since the oil pressure "wasn't working" when you picked it up). Hydraulic lifters need good oil pressure, its like your heart pumping without blood.
Good luck dude I hope it gets figured out quick.
Like I said that's a total off the wall guess and I'm probably wrong so don't crucify me if I am.
carsaremytoys
06-11-13, 06:59 AM
I do have the collapsed lifter.
carsaremytoys
06-11-13, 09:37 AM
They charged me for a new head gasket, but I never saw it with the head off.
thebigjimsho
06-11-13, 02:35 PM
Hamsters on a wheel can churn more than 3psi...
carsaremytoys
06-11-13, 07:57 PM
He had the nerve to tell me that I was pissing him off today when I took the car back, what happened to customer service? Paying customers don't mean shit anymore. He continued to blow off the noise, and even blamed it on the super charger. I asked him if he had a stethoscope, to which he replied "i have a screwdriver" I asked if he would get it so that we could pin point the noise. He was an ass and stated that he would have to charge me for this. I asked if he would listen if I got mine and he agreed. He also claimed in a scarcastic way that he obviously knows nothing of what a supercharger sounds like... Well, we each had a listen with my stethoscope and learned that the noise was coming from the head that he had previously taken off. Hmmm, I guess he doesn't know what a super charger sounds like. He says he'll tear into it again. But should I really have to go through all of this?!? I'm dumbfounded how someone can stay in business with this attitute toward paying customers.
RyRidesMotoX
06-11-13, 10:50 PM
What shop is this? You should post the name so people don't go there and get screwed by this guy again. I'm not sure how much he charged you but it may be time to go somewhere else. Maybe try and get money back in small claims court but it may not be worth the trouble to try and get the money back.
izcain
06-11-13, 11:23 PM
Post a pic of the lifter I would like to see it!
JFensty
06-12-13, 12:40 PM
If you can't get the money back, take the loss and go somewhere else before he screws something else up and costs you the motor.
izcain
06-12-13, 03:33 PM
If they haven't done something already.
I agree with above. Find someone else that is competent. Telling you he is getting pissed just tells me he should DEFINITLY not be touching anything.
carsaremytoys
06-12-13, 06:44 PM
He put in another set of rockers and the noise went away, I can't explain it and neither can he. He said he is going to put the yella terras back in and see if the noise Comes back. He was very pleasant to work with today. Caught him at a bad time yesterday maybe, but so far he is making good.
RyRidesMotoX
06-12-13, 07:06 PM
He was pmsing??? Take him a tampon next time... Or get a camera and film a snickers commercial... Be like - hey mechanic have a snicker... "Why?" Because you turn into my mother in law when your hungry... Better? "Better!" Good now go put my car back together
carsaremytoys
06-12-13, 07:08 PM
116162
<a href="http://s262.photobucket.com/user/Mattyone1984/media/collapsedlifter1_zps19f778cc.jpg.html" target="_blank"><img src="http://i262.photobucket.com/albums/ii82/Mattyone1984/collapsedlifter1_zps19f778cc.jpg" border="0" alt=" photo collapsedlifter1_zps19f778cc.jpg"/></a>
carsaremytoys
06-13-13, 09:12 PM
Brought her home today, so far so good. He switched to all stock rockers .
RyRidesMotoX
06-13-13, 10:22 PM
Maybe one of the rockers was cracked. Sometimes its hard to see them like if they are cracked on the bottom (the head side). Did he let you check them out
carsaremytoys
06-14-13, 07:02 AM
I have them, I haven't given them a look yet.
darkman
06-14-13, 07:45 AM
If the rockers in question are Yella Terra shaft mounts, they require a little more attention to setup properly. You have to establish a proper wipe pattern by adding or subtracting shims and then establish the proper pushrod length using either an adjustable pushrod or dial indicator. Many of the problems reported with Yella Terras are the result of improper setup.
